Hi guys, once again I have changed absolutely nothing on my aapanel but now I am having FTP problems again. Does anybody know why i cannot connect here it only happens in passive mode And I have all my ports open 21, 39000-40000. it just started happening. i have also rebooted my server
. 2022-06-15 10:57:01.153 --------------------------------------------------------------------------
. 2022-06-15 10:57:01.154 WinSCP Version 5.19.5 (Build 11933 2021-11-25) (OS 10.0.22000 - Windows 10 Enterprise)
. 2022-06-15 10:57:01.154 Configuration: HKCU\Software\Martin Prikryl\WinSCP 2\
. 2022-06-15 10:57:01.154 Log level: Normal
. 2022-06-15 10:57:01.154 Local account: DARRELLMSI\dcunn
. 2022-06-15 10:57:01.154 Working directory: C:\Program Files (x86)\WinSCP
. 2022-06-15 10:57:01.154 Process ID: 28156
. 2022-06-15 10:57:01.154 Ancestor processes: explorer, ...
. 2022-06-15 10:57:01.154 Command-line: "C:\Program Files (x86)\WinSCP\WinSCP.exe"
. 2022-06-15 10:57:01.154 Time zone: Current: GMT-6, Standard: GMT-7 (Mountain Standard Time), DST: GMT-6 (Mountain Daylight Time), DST Start: 3/13/2022, DST End: 11/6/2022
. 2022-06-15 10:57:01.155 Login time: Wednesday, June 15, 2022 10:57:01 AM
. 2022-06-15 10:57:01.155 --------------------------------------------------------------------------
. 2022-06-15 10:57:01.155 Session name: Master@131.153.160.82 (Site)
. 2022-06-15 10:57:01.155 Host name: 131.153.160.82 (Port: 21)
. 2022-06-15 10:57:01.155 User name: Master (Password: Yes, Key file: No, Passphrase: No)
. 2022-06-15 10:57:01.155 Transfer Protocol: FTP
. 2022-06-15 10:57:01.155 Ping type: Dummy, Ping interval: 30 sec; Timeout: 15 sec
. 2022-06-15 10:57:01.155 Disable Nagle: No
. 2022-06-15 10:57:01.155 Proxy: None
. 2022-06-15 10:57:01.155 Send buffer: 262144
. 2022-06-15 10:57:01.155 UTF: Auto
. 2022-06-15 10:57:01.155 FTPS: None [Client certificate: No]
. 2022-06-15 10:57:01.155 FTP: Passive: Yes [Force IP: Auto]; MLSD: Auto [List all: Auto]; HOST: Auto
. 2022-06-15 10:57:01.155 Local directory: D:\websites, Remote directory: /, Update: Yes, Cache: Yes
. 2022-06-15 10:57:01.155 Cache directory changes: Yes, Permanent: Yes
. 2022-06-15 10:57:01.155 Recycle bin: Delete to: No, Overwritten to: No, Bin path:
. 2022-06-15 10:57:01.155 Timezone offset: 0h 0m
. 2022-06-15 10:57:01.194 Connecting to 131.153.160.82 ...
. 2022-06-15 10:57:01.225 Connected with 131.153.160.82. Waiting for welcome message...
< 2022-06-15 10:57:01.286 220---------- Welcome to Pure-FTPd [privsep] [TLS] ----------
< 2022-06-15 10:57:01.286 220-You are user number 1 of 50 allowed.
< 2022-06-15 10:57:01.286 220-Local time is now 10:57. Server port: 21.
< 2022-06-15 10:57:01.286 220-This is a private system - No anonymous login
< 2022-06-15 10:57:01.286 220-IPv6 connections are also welcome on this server.
< 2022-06-15 10:57:01.286 220 You will be disconnected after 15 minutes of inactivity.
2022-06-15 10:57:01.286 USER Master
< 2022-06-15 10:57:01.348 331 User Master OK. Password required
2022-06-15 10:57:01.348 PASS **********
< 2022-06-15 10:57:01.486 230 OK. Current directory is /
2022-06-15 10:57:01.486 SYST
< 2022-06-15 10:57:01.548 215 UNIX Type: L8
2022-06-15 10:57:01.548 FEAT
< 2022-06-15 10:57:01.604 211-Extensions supported:
< 2022-06-15 10:57:01.604 UTF8
< 2022-06-15 10:57:01.604 EPRT
< 2022-06-15 10:57:01.604 IDLE
< 2022-06-15 10:57:01.604 MDTM
< 2022-06-15 10:57:01.604 SIZE
< 2022-06-15 10:57:01.604 MFMT
< 2022-06-15 10:57:01.604 REST STREAM
< 2022-06-15 10:57:01.604 MLST type;size;sizd;modify;UNIX.mode;UNIX.uid;UNIX.gid;unique;
< 2022-06-15 10:57:01.604 MLSD
< 2022-06-15 10:57:01.604 PRET
< 2022-06-15 10:57:01.604 AUTH TLS
< 2022-06-15 10:57:01.604 PBSZ
< 2022-06-15 10:57:01.604 PROT
< 2022-06-15 10:57:01.604 TVFS
< 2022-06-15 10:57:01.604 ESTA
< 2022-06-15 10:57:01.604 PASV
< 2022-06-15 10:57:01.604 EPSV
< 2022-06-15 10:57:01.604 SPSV
< 2022-06-15 10:57:01.604 211 End.
2022-06-15 10:57:01.604 OPTS UTF8 ON
< 2022-06-15 10:57:01.661 504 Unknown command
. 2022-06-15 10:57:01.699 Connected
. 2022-06-15 10:57:01.699 --------------------------------------------------------------------------
. 2022-06-15 10:57:01.699 Using FTP protocol.
. 2022-06-15 10:57:01.699 Doing startup conversation with host.
2022-06-15 10:57:01.715 PWD
< 2022-06-15 10:57:01.783 257 "/" is your current location
. 2022-06-15 10:57:01.783 Changing directory to "/".
2022-06-15 10:57:01.783 CWD /
< 2022-06-15 10:57:01.847 250 OK. Current directory is /
. 2022-06-15 10:57:01.847 Getting current directory name.
2022-06-15 10:57:01.847 PWD
< 2022-06-15 10:57:01.909 257 "/" is your current location
. 2022-06-15 10:57:01.988 Retrieving directory listing...
2022-06-15 10:57:01.988 TYPE A
< 2022-06-15 10:57:02.046 200 TYPE is now ASCII
2022-06-15 10:57:02.046 PASV
. 2022-06-15 10:57:17.141 Timeout detected. (control connection)
. 2022-06-15 10:57:17.141 Could not retrieve directory listing
- 2022-06-15 10:57:17.210 (EFatal) Lost connection.
- 2022-06-15 10:57:17.210 Timeout detected. (control connection)
- 2022-06-15 10:57:17.210 Could not retrieve directory listing
- 2022-06-15 10:57:17.210 Error listing directory '/'.
