Hello, Im receiving this error mentioned in the title, anyone knows what could be wrong?
I tried repairing the file multiple times and reinstalling the panel, but it didn't work. Any help great, thank you!
Jun 16 20:31:40 vmi624567 postfix/postfix-script[4292]: starting the Postfix mail system
Jun 16 20:31:40 vmi624567 postfix/master[4294]: fatal: bind 0.0.0.0 port 25: Address already in use
Jun 16 20:31:41 vmi624567 postfix/master[4293]: fatal: daemon initialization failure
Jun 16 20:31:42 vmi624567 postfix/postfix-script[4295]: fatal: mail system startup failed
Jun 16 20:31:53 vmi624567 postfix/postfix-script[4859]: starting the Postfix mail system
Jun 16 20:31:53 vmi624567 postfix/master[4861]: fatal: bind 0.0.0.0 port 25: Address already in use
Jun 16 20:31:54 vmi624567 postfix/master[4860]: fatal: daemon initialization failure
Jun 16 20:31:55 vmi624567 postfix/postfix-script[4863]: fatal: mail system startup failed
Jun 16 20:32:07 vmi624567 postfix/postfix-script[4991]: starting the Postfix mail system
Jun 16 20:32:07 vmi624567 postfix/master[4993]: fatal: bind 0.0.0.0 port 25: Address already in use
Jun 16 20:32:08 vmi624567 postfix/master[4992]: fatal: daemon initialization failure
Jun 16 20:32:09 vmi624567 postfix/postfix-script[4995]: fatal: mail system startup failed
Jun 16 20:33:50 vmi624567 postfix/postfix-script[5188]: starting the Postfix mail system
Jun 16 20:33:50 vmi624567 postfix/master[5190]: fatal: bind 0.0.0.0 port 25: Address already in use
Jun 16 20:33:51 vmi624567 postfix/master[5189]: fatal: daemon initialization failure
Jun 16 20:33:52 vmi624567 postfix/postfix-script[5191]: fatal: mail system startup failed
Jun 16 20:36:13 vmi624567 postfix/postfix-script[5374]: starting the Postfix mail system
Jun 16 20:36:13 vmi624567 postfix/master[5376]: fatal: bind 0.0.0.0 port 25: Address already in use
Jun 16 20:36:14 vmi624567 postfix/master[5375]: fatal: daemon initialization failure
Jun 16 20:36:15 vmi624567 postfix/postfix-script[5377]: fatal: mail system startup failed
Jun 16 20:36:16 vmi624567 postfix/postfix-script[5386]: fatal: the Postfix mail system is not running
Jun 16 20:36:40 vmi624567 postfix/postfix-script[5752]: starting the Postfix mail system
Jun 16 20:36:40 vmi624567 postfix/master[5754]: fatal: bind 0.0.0.0 port 25: Address already in use
Jun 16 20:36:41 vmi624567 postfix/master[5753]: fatal: daemon initialization failure
Jun 16 20:36:42 vmi624567 postfix/postfix-script[5755]: fatal: mail system startup failed
Jun 16 20:36:44 vmi624567 postfix/postfix-script[5968]: starting the Postfix mail system
Jun 16 20:36:44 vmi624567 postfix/master[5970]: fatal: bind 0.0.0.0 port 25: Address already in use
Jun 16 20:36:45 vmi624567 postfix/master[5969]: fatal: daemon initialization failure
Jun 16 20:36:46 vmi624567 postfix/postfix-script[5971]: fatal: mail system startup failed
Jun 16 20:36:52 vmi624567 postfix/postfix-script[6300]: starting the Postfix mail system
Jun 16 20:36:52 vmi624567 postfix/master[6302]: fatal: bind 0.0.0.0 port 25: Address already in use
Jun 16 20:36:53 vmi624567 postfix/master[6301]: fatal: daemon initialization failure
Jun 16 20:36:54 vmi624567 postfix/postfix-script[6303]: fatal: mail system startup failed
Jun 16 20:37:10 vmi624567 postfix/postfix-script[6461]: starting the Postfix mail system
Jun 16 20:37:10 vmi624567 postfix/master[6463]: fatal: bind 0.0.0.0 port 25: Address already in use
Jun 16 20:37:11 vmi624567 postfix/master[6462]: fatal: daemon initialization failure
Jun 16 20:37:12 vmi624567 postfix/postfix-script[6464]: fatal: mail system startup failed
Jun 16 20:37:57 vmi624567 dovecot: master: Warning: Killed with signal 15 (by pid=7132 uid=0 code=kill)
Jun 16 20:48:16 vmi624567 postfix/postfix-script[11344]: starting the Postfix mail system
Jun 16 20:48:16 vmi624567 postfix/master[11346]: fatal: bind 0.0.0.0 port 25: Address already in use
Jun 16 20:48:17 vmi624567 postfix/master[11345]: fatal: daemon initialization failure
Jun 16 20:48:18 vmi624567 postfix/postfix-script[11349]: fatal: mail system startup failed
Jun 16 20:59:09 vmi624567 postfix/postfix-script[17036]: starting the Postfix mail system
Jun 16 20:59:09 vmi624567 postfix/master[17038]: fatal: bind 0.0.0.0 port 25: Address already in use
Jun 16 20:59:10 vmi624567 postfix/master[17037]: fatal: daemon initialization failure
Jun 16 20:59:11 vmi624567 postfix/postfix-script[17041]: fatal: mail system startup failed
Jun 16 20:59:15 vmi624567 dovecot: master: Dovecot v2.2.33.2 (d6601f4ec) starting up for imap, pop3, lmtp (core dumps disabled)
Jun 16 20:59:18 vmi624567 dovecot: master: Warning: Killed with signal 15 (by pid=17192 uid=0 code=kill)
Jun 16 20:59:18 vmi624567 dovecot: master: Dovecot v2.2.33.2 (d6601f4ec) starting up for imap, pop3, lmtp (core dumps disabled)
Jun 16 20:59:18 vmi624567 postfix/postfix-script[17354]: starting the Postfix mail system
Jun 16 20:59:18 vmi624567 postfix/master[17356]: fatal: bind 0.0.0.0 port 25: Address already in use
Jun 16 20:59:19 vmi624567 postfix/master[17355]: fatal: daemon initialization failure
Jun 16 20:59:20 vmi624567 postfix/postfix-script[17374]: fatal: mail system startup failed
Jun 16 21:00:23 vmi624567 postfix/postfix-script[17539]: starting the Postfix mail system
Jun 16 21:00:23 vmi624567 postfix/master[17541]: fatal: bind 0.0.0.0 port 25: Address already in use
Jun 16 21:00:24 vmi624567 postfix/master[17540]: fatal: daemon initialization failure
Jun 16 21:00:25 vmi624567 postfix/postfix-script[17542]: fatal: mail system startup failed
Jun 16 21:01:26 vmi624567 postfix/postfix-script[18504]: starting the Postfix mail system
Jun 16 21:01:26 vmi624567 postfix/master[18506]: fatal: bind 0.0.0.0 port 25: Address already in use
Jun 16 21:01:27 vmi624567 postfix/master[18505]: fatal: daemon initialization failure
Jun 16 21:01:28 vmi624567 postfix/postfix-script[18507]: fatal: mail system startup failed
Jun 16 21:01:38 vmi624567 postfix/postfix-script[19037]: starting the Postfix mail system
Jun 16 21:01:38 vmi624567 postfix/master[19039]: fatal: bind 0.0.0.0 port 25: Address already in use
Jun 16 21:01:39 vmi624567 postfix/master[19038]: fatal: daemon initialization failure
Jun 16 21:01:40 vmi624567 postfix/postfix-script[19040]: fatal: mail system startup failed
Jun 16 21:02:30 vmi624567 postfix/postfix-script[19186]: starting the Postfix mail system
Jun 16 21:02:30 vmi624567 postfix/master[19188]: fatal: bind 0.0.0.0 port 25: Address already in use
Jun 16 21:02:31 vmi624567 postfix/master[19187]: fatal: daemon initialization failure
Jun 16 21:02:32 vmi624567 postfix/postfix-script[19189]: fatal: mail system startup failed
