I'm currently trying to get n8n running on my installation using a docker container but I can't seem to manage to get it right using aaPanel. I've created the container, set up the port and get a clear message that my app is currently running on the container, but can't access it:
If I go to the URL there's a timeout:
I even added a reverse proxy to the website (which is using SSL) so to try to not use the port on the frontend, but got the same results.
