2022-07-05T04:03:48.862489Z 0 [Warning] option 'max_allowed_packet': unsigned value 107374182400 adjusted to 107374
1824
2022-07-05T04:03:48.862708Z 0 [Warning] 'NO_ZERO_DATE', 'NO_ZERO_IN_DATE' and 'ERROR_FOR_DIVISION_BY_ZERO' sql mode
s should be used with strict mode. They will be merged with strict mode in a future release.
2022-07-05T04:03:48.862720Z 0 [Warning] 'NO_AUTO_CREATE_USER' sql mode was not set.
2022-07-05T04:03:48.862760Z 0 [Note] --secure-file-priv is set to NULL. Operations related to importing and exporti
ng data are disabled
2022-07-05T04:03:48.862818Z 0 [Note] /www/server/mysql/bin/mysqld (mysqld 5.7.38-log) starting as process 9496 ...
2022-07-05T04:03:48.885764Z 0 [Note] InnoDB: PUNCH HOLE support available
2022-07-05T04:03:48.885843Z 0 [Note] InnoDB: Mutexes and rw_locks use GCC atomic builtins
2022-07-05T04:03:48.885851Z 0 [Note] InnoDB: Uses event mutexes
2022-07-05T04:03:48.885857Z 0 [Note] InnoDB: GCC builtin __atomic_thread_fence() is used for memory barrier
2022-07-05T04:03:48.885888Z 0 [Note] InnoDB: Compressed tables use zlib 1.2.11
2022-07-05T04:03:48.885897Z 0 [Note] InnoDB: Using Linux native AIO
2022-07-05T04:03:48.886531Z 0 [Note] InnoDB: Number of pools: 1
2022-07-05T04:03:49.062384Z 0 [Note] InnoDB: Highest supported file format is Barracuda.
2022-07-05T04:03:49.107318Z 0 [Note] InnoDB: Creating shared tablespace for temporary tables
2022-07-05T04:03:49.107435Z 0 [Note] InnoDB: Setting file '/www/server/data/ibtmp1' size to 12 MB. Physically writi
ng the file full; Please wait ...
2022-07-05T04:03:49.130508Z 0 [Note] InnoDB: File '/www/server/data/ibtmp1' size is now 12 MB.
2022-07-05T04:03:49.131742Z 0 [Note] InnoDB: 96 redo rollback segment(s) found. 96 redo rollback segment(s) are act
ive.
2022-07-05T04:03:49.131774Z 0 [Note] InnoDB: 32 non-redo rollback segment(s) are active.
2022-07-05T04:03:49.132119Z 0 [Note] InnoDB: Waiting for purge to start
2022-07-05T04:03:49.290094Z 0 [Note] InnoDB: 5.7.38 started; log sequence number 623838936493
2022-07-05T04:03:49.290528Z 0 [Note] Plugin 'FEDERATED' is disabled.
mysqld: File './mysql-bin.000036' not found (Errcode: 2 - No such file or directory)
2022-07-05T04:03:49.295474Z 0 [ERROR] Failed to open log (file './mysql-bin.000036', errno 2)
2022-07-05T04:03:49.295482Z 0 [ERROR] Could not open log file
2022-07-05T04:03:49.295490Z 0 [ERROR] Can't init tc log
2022-07-05T04:03:49.295495Z 0 [ERROR] Aborting
2022-07-05T04:03:49.295511Z 0 [Note] Binlog end
2022-07-05T04:03:49.295753Z 0 [Note] Shutting down plugin 'ngram'
2022-07-05T04:03:49.295766Z 0 [Note] Shutting down plugin 'partition'
2022-07-05T04:03:49.295771Z 0 [Note] Shutting down plugin 'BLACKHOLE'
2022-07-05T04:03:49.295776Z 0 [Note] Shutting down plugin 'ARCHIVE'
2022-07-05T04:03:49.295780Z 0 [Note] Shutting down plugin 'PERFORMANCE_SCHEMA'
2022-07-05T04:03:49.295885Z 0 [Note] Shutting down plugin 'MRG_MYISAM'
2022-07-05T04:03:49.295899Z 0 [Note] Shutting down plugin 'MyISAM'
2022-07-05T04:03:49.295916Z 0 [Note] Shutting down plugin 'INNODB_SYS_VIRTUAL'
[modernbit1999@instance-3 ~]$
