Hyperizon First of all thanks for the solution, today I started getting this error while upgrading the panel to the new version. But I don't want to use secure entrance how do I solve this?
aaP_alimehran200 dear sir. i have the same problem. i tried all the possible ways from this forum. today i added more ips to my aapanel after that my account show this error "Please use the correct Ingress " , or some times 404 nginx . my ip and other credientials i can provide. please help i even dont have backup. thanks
aaPanel_Kern aaP_alimehran200 Hi try to unrestrict ip:bt 13 Cancel domain name binding: bt 12 If there is a security entry, please check whether it is correct: You can use the SSH tool to log in to the server and execute the command to view the default information: bt 14 If there is no security entry, please add:/login after the link tutorial: https://www.aapanel.com/forum/d/13132-aapanel-cannot-log-in-and-cannot-be-accessed-workaround
aaP_alimehran200 its solved thatnks... now next problem. no plugin can install. the log just show Loading
aaPanel_Kern aaP_alimehran200 Hi, have you set up a subdomain for the panel? If so, use a subdomain for access. After setting the subdomain ip will disable access. What plugin did you install? Did trying restarting the panel fix it?
aaP_alimehran200 dear.. sir. i tried all the possible ways didnt worked. at last i reinstall the pannel then got also backup of previous data. later i faced the webserver down error. the webserver provider told me that your server is live. in the end i reinstalled the Centos OS and fresh installed the aapanel. after that everthing is smooth. now i have decided that i will not change any settings in the aapel that i am not familiar. 🙂 thanks for your support. 😀
aaPanel_Kern aaP_quanseo101 Hi, do you have the full input link? Use the ssh tool to log in to the server, and then execute the command to view the default information: bt 14 If there is no security entry, please add:/login after the link
aaP_carmo_liu please use the correct ingress i can login successfully by chrome, but failed by other explorers, and also failed on other pcs(no matter which explorer), why? just few minuttes later, all failed totally!
aaPanel_Kern aaP_carmo_liu Hello, please check whether you have access to the panel using the full link. You can use the command to view: bt 14 If there is no security portal, please add /login at the end of the link
aaP_carmo_liu aaPanel_Kern i see the link and username, pwd, but when i login, it says wrong username or pwd
aaP_carmo_liu aaPanel_Kern bt 14 list the link, username, pwd, but login failed, it says invalid username or pwd, how could it be? why? pls help, thanks
aaPanel_Kern aaP_carmo_liu Hello, the password viewed with the command 'bt 14' is not the actual password. If you forget, please use 'bt 5' to change the password, and then use the new password to log in to the panel
