aaPanel_Kern Hamka Hello, the panel app store provides an easy-to-use Load balance. If you configure it yourself, it is recommended to use a search engine to query for more detailed tutorials.
Hamka aaPanel_Kern please try to manually configure the load balancer on nginx aapanel (manual method / without using a plugin)
aaPanel_Kern Hamka I mean in which config file are you configured. I can configure it for sure. This has nothing to do with aapanel or not.
Hamka aaPanel_Kern I have configured it..but it doesn't work..please see the addition of the blue code
aaPanel_Kern Hamka This is the site setting. Certainly not. Requires nginx configuration settings in the app store
Hamka aaPanel_Kern should work if using this method http://nginx.org/en/docs/http/load_balancing.html
Hamka aaPanel_Kern i have followed this....and it should be configured on the domain .. please see this .. https://www.linuxsec.org/2017/07/konfigurasi-load-balancing-dengan-nginx.html?m=1
Hamka on the green circle.. is the configuration location on the domain that is used as a load balancer...then on the red circle is the server that is used as the backend
