DAMO Hia i added a domain name to my panel and it don't load like its gone is there anything i cant do to fix it. ?
aaPanel_Kern DAMO Hi, are you using a domain name to access the panel? The domain name needs to be an A record pointing to the ip of the server Use the domain name to access the panel. After the domain name is set on the panel, IP access will be prohibited, and only the domain name can be used to access. Use the SSH tool to log in to the server and execute the command to cancel the domain name: bt 12 Reference tutorial: https://www.aapanel.com/forum/d/13132-aapanel-cannot-log-in-and-cannot-be-accessed-workaround
