aaPanel_Kern RonnyyApp Hi, is the problem solved? I don't see that port 7800 is running, please check whether the panel is running: bt status If not please check the log of the panel: bt 22 Try restarting the panel: bt restart
kahyam_info I have the same problem, I don't know how to solve it, but when stop_rp_when_renew_ssl.pl is deleted, the http port froze, entering the panel, I enter username and password, no action file path /www/server/panel/data/ stop_rp_when_renew_ssl.pl
aaPanel_Kern kahyam_info Hi, is the problem solved? I don't see that port 7800 is running, please check whether the panel is running: bt status If not please check the log of the panel: bt 22 Try restarting the panel: bt restart
