decen Hello everyone, I have an issue, can't access phpMyAdmin (PHP 7.4): Tried to reinstall phpMyAdmin, and switch the PHP version, didn't help. 405 Not Allowed nginx
aaPanel_Kern decen Hi. Try restarting nginx and all php, can it be solved? If it still doesn't work, click "Restart Server" in "Restart" on the home page, can it be solved?
decen SOLVED. Installed nginx 1.20 / php 7.4 / phpmyadmin 5 / Ubuntu 22.04.1 Suggest there is some issue with nginx 1.21 / phpmyadmin 5 and Ubuntu 22.04.1
aaP_riazeeshan Dear Friends - Same Error which I am facing ! any possible solution ? below are the Server Specs Server Specs Centos 8.0 Nginx 1.24.0 MySQL 8.0.36 PHP-8.2 MyPHP Admin82
aaP_riazeeshan Nop sir @aaPanel_Kern I have to re configure the website, what is the best OS for Openlightspeed Server ?
aaPanel_Kern Hello, try restarting nginx. Is it normal for the browser to access in traceless mode? aaP_thomas.bolley
aaPanel_Kern Hello, is it normal now? If it is not normal, you can try reinstalling nginx aaP_thomas.bolley
aaP_thomas.bolley on change back to ubuntu 24.04 problem are solved, seems on debian 13 have some troubles
