The plugin was working perfect, I have updated and it doesn't work. I have reinstalled, deleted by terminal and reinstalled by terminal, nothing works.
In the terminal it tells me that mongodb is running
Log Mongodb:
{"t":{"$date":"2022-08-30T22:26:01.473-04:00"},"s":"I", "c":"CONTROL", "id":23285, "ctx":"main","msg":"Automatically disabling TLS 1.0, to force-enable TLS 1.0 specify --sslDisabledProtocols 'none'"}
{"t":{"$date":"2022-08-30T22:26:01.474-04:00"},"s":"W", "c":"ASIO", "id":22601, "ctx":"main","msg":"No TransportLayer configured during NetworkInterface startup"}
{"t":{"$date":"2022-08-30T22:26:01.474-04:00"},"s":"I", "c":"NETWORK", "id":4648601, "ctx":"main","msg":"Implicit TCP FastOpen unavailable. If TCP FastOpen is required, set tcpFastOpenServer, tcpFastOpenClient, and tcpFastOpenQueueSize."}
{"t":{"$date":"2022-08-30T22:26:01.475-04:00"},"s":"I", "c":"STORAGE", "id":4615611, "ctx":"initandlisten","msg":"MongoDB starting","attr":{"pid":21607,"port":27017,"dbPath":"/www/server/mongodb/data","architecture":"64-bit","host":"dode"}}
{"t":{"$date":"2022-08-30T22:26:01.475-04:00"},"s":"I", "c":"CONTROL", "id":23403, "ctx":"initandlisten","msg":"Build Info","attr":{"buildInfo":{"version":"4.4.6","gitVersion":"72e66213c2c3eab37d9358d5e78ad7f5c1d0d0d7","openSSLVersion":"OpenSSL 1.1.1i 8 Dec 2020","modules":[],"allocator":"tcmalloc","environment":{"distmod":"ubuntu2004","distarch":"x86_64","target_arch":"x86_64"}}}}
{"t":{"$date":"2022-08-30T22:26:01.475-04:00"},"s":"I", "c":"CONTROL", "id":51765, "ctx":"initandlisten","msg":"Operating System","attr":{"os":{"name":"Ubuntu","version":"20.04"}}}
{"t":{"$date":"2022-08-30T22:26:01.475-04:00"},"s":"I", "c":"CONTROL", "id":21951, "ctx":"initandlisten","msg":"Options set by command line","attr":{"options":{"config":"/www/server/mongodb/config.conf","net":{"bindIp":"127.0.0.1","port":27017},"processManagement":{"fork":true,"pidFilePath":"/www/server/mongodb/log/configsvr.pid"},"security":{"authorization":"disabled","javascriptEnabled":false},"storage":{"dbPath":"/www/server/mongodb/data","directoryPerDB":true,"journal":{"enabled":true}},"systemLog":{"destination":"file","logAppend":true,"path":"/www/server/mongodb/log/config.log"}}}}
{"t":{"$date":"2022-08-30T22:26:01.475-04:00"},"s":"E", "c":"NETWORK", "id":23024, "ctx":"initandlisten","msg":"Failed to unlink socket file","attr":{"path":"/tmp/mongodb-27017.sock","error":"Operation not permitted"}}
{"t":{"$date":"2022-08-30T22:26:01.475-04:00"},"s":"F", "c":"-", "id":23091, "ctx":"initandlisten","msg":"Fatal assertion","attr":{"msgid":40486,"file":"src/mongo/transport/transport_layer_asio.cpp","line":919}}
{"t":{"$date":"2022-08-30T22:26:01.475-04:00"},"s":"F", "c":"-", "id":23092, "ctx":"initandlisten","msg":"\n\n***aborting after fassert() failure\n\n"}
Mongodb Instale
cp: cannot create regular file '/www/server/panel/static/img/soft_ico/ico-mongodb.png': No such file or directory
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = "en_US:en",
LC_ALL = (unset),
LC_CTYPE = "C.UTF-8",
LANG = "en_US.UTF-8"
are supported and installed on your system.
perl: warning: Falling back to the standard locale ("C").
--2022-08-30 22:26:02-- http://128.1.164.196/tools/check.sh
Connecting to 128.1.164.196:80... connected.
Length: 565 [application/octet-stream]
Saving to: '/www/server/panel/install/check.sh'
0K 100% 109M=0s
2022-08-30 22:26:02 (109 MB/s) - '/www/server/panel/install/check.sh' saved [565/565]
|-Successify ---Script execution completed---
