khmerzoon
Hello, please use the SSH tool to log in to the server to see what the current link of the panel is. Check the execution command: bt 14
After the panel has set the domain, it can only be accessed using the domain, and the ip will prohibit access to the panel. The domain name needs to be an A record pointing to the server's ip, and a proxy cannot be used.
Cancel domain name command: bt 12
https://www.aapanel.com/forum/d/13132-aapanel-cannot-log-in-and-cannot-be-accessed-workaround
