I have an error message also in the task.log :
This typically means that you attempted to use functionality that needed
an active HTTP request. Consult the documentation on testing for
information about how to avoid this problem.
File "/www/server/panel/script/mysql_quota.py", line 9, in <module>
p.mysql_quota_check()
File "class/projectModel/quotaModel.py", line 150, in mysql_quota_check
if not OO0O0OOO00O0OO00O .__OO000OOO0OO0O00OO ():return public .returnMsg (False ,OO0O0OOO00O0OO00O .__O0O00000000OOO0O0 )
File "class/projectModel/quotaModel.py", line 201, in __OO000OOO0OO0O00OO
O0O0O00O0OO00O000 =panelPlugin .panelPlugin ().get_soft_list (O0OOOOOO0O0000O0O )
File "class/panelPlugin.py", line 690, in get_soft_list
softList = self.get_cloud_list(get)
File "class/panelPlugin.py", line 344, in get_cloud_list
if 'focre_cloud' in session:
File "/www/server/panel/pyenv/lib/python3.7/site-packages/werkzeug/local.py", line 379, in <lambda>
__contains__ = lambda x, i: i in x._get_current_object()
File "/www/server/panel/pyenv/lib/python3.7/site-packages/werkzeug/local.py", line 306, in _get_current_object
return self.__local()
File "/www/server/panel/pyenv/lib/python3.7/site-packages/flask/globals.py", line 38, in _lookup_req_object
raise RuntimeError(_request_ctx_err_msg)
RuntimeError: Working outside of request context.
I don't know if this is related to my problem.
