aaPanel_Kern one_group Hello, please check if the newly added storage is mounted? Use the command to see if the current storage information is the same as that displayed on the panel: df -h && lsblk
aaPanel_Kern one_group The hard disk is not mounted, it is mounted first. Can be found using a search engine. Please take a system snapshot before operation. If you do not understand, it is recommended to ask the server provider for help
