how to add port other than 443 in nginx?
I tried to add port 2122 for ssl which is the same as 443, but i newbie can help me @aaPanel_Kern
thank before 🙂
server
listen 80;
listen 443 ssl http2;
listen 2122 ssl http2;
server_name dev.blablabla.com;
root /www/wwwroot/dev.blablabla.com/public;
#error_page 404/404.html;
#HTTP_TO_HTTPS_START
if ($server_port !~ 443){
rewrite ^(/.*)$ https://$host$1 permanent;
#HTTP_TO_HTTPS_END
ssl_certificate /www/server/panel/vhost/cert/dev.blablabla.com/fullchain.pem;
ssl_certificate_key /www/server/panel/vhost/cert/dev.blablabla.com/privkey.pem;
ssl_prefer_server_ciphers on;
ssl_session_timeout 10m;
#SSL-END
#error_page 404 /404.html;
#error_page 502 /502.html;
#ERROR-PAGE-END
include enable-php-80.conf;
#PHP-INFO-END
include /www/server/panel/vhost/rewrite/dev.blablabla.com.conf;
#REWRITE-END
location ~ ^/(\.user.ini|\.htaccess|\.git|\.svn|\.project|LICENSE|README.md)
return 404;
location ~ \.well-known{
allow all;
expires 30d;
error_log /dev/null;
access_log off;
location ~ .*\.(js|css)?$
expires 12h;
access_log off;
access_log /www/wwwlogs/dev.blablabla.com.log;
error_log /www/wwwlogs/dev.blablabla.com.error.log;
