aaP_me12 Following a reboot SSH turned itself off, it now won't turn back on. Repairing and restarting the panel makes no difference. The internal terminal also fails with the correct root password.
aaPanel_Kern aaP_me12 Hello, can I log in to the server using SSH tool? If not. Please use VNC on the server provider's website to check whether SSH is started At the same time, this is the service provided by ssh. Repairing the restart panel cannot be repaired systemctl status sshd systemctl start sshd
aaP_me12 Of course you can't, SSH isn't working, that's the whole point of these posts! The panel appears to have broken SSH, and contains a toggle for SSH so presumably it is the source of the issue.
aaPanel_Kern aaP_me12 This is just the SSH switch. Can you take a screenshot or provide the result of executing the command? Is SSH running? Can I start it manually? At most, the panel cannot determine whether SSH is running and will not be damaged.
aaP_me12 aaPanel_Kern If I can't ssh in and the internal terminal doesn't work, how do you imagine I can run a command?
