[root@solisitor ~]# tail -n200 /var/log/rspamd/rspamd.log
2022-11-01 05:22:39 #20797(main) <3j8rf1>; lua; trie.lua:167: no tries defined
2022-11-01 05:22:39 #20797(main) <3j8rf1>; cfg; rspamd_init_lua_filters: init lua module trie from /usr/share/rspamd/plugins/trie.lua; digest: eeaf4aab9f
2022-11-01 05:22:39 #20797(main) <3j8rf1>; lua; lua_redis.lua:574: use default Redis settings for url_redirector
2022-11-01 05:22:39 #20797(main) <3j8rf1>; lua; url_redirector.lua:339: no redirector_hosts_map option is specified, disabling module
2022-11-01 05:22:39 #20797(main) <3j8rf1>; cfg; rspamd_init_lua_filters: init lua module url_redirector from /usr/share/rspamd/plugins/url_redirector.lua; digest: e000e2e07d
2022-11-01 05:22:39 #20797(main) <3j8rf1>; cfg; rspamd_map_parse_backend: map '/etc/rspamd/local.d/maps.d/spf_whitelist.inc.local' is not found, but it can be loaded automatically later
2022-11-01 05:22:39 #20797(main) <3j8rf1>; cfg; rspamd_map_parse_backend: map '/var/lib/rspamd/spf_whitelist.inc.local' is not found, but it can be loaded automatically later
2022-11-01 05:22:39 #20797(main) <3j8rf1>; cfg; rspamd_map_parse_backend: map '/etc/rspamd/maps.d/spf_whitelist.inc' is not found, but it can be loaded automatically later
2022-11-01 05:22:39 #20797(main) <3j8rf1>; cfg; rspamd_map_parse_backend: map '/etc/rspamd/local.d/maps.d/dmarc_whitelist.inc.local' is not found, but it can be loaded automatically later
2022-11-01 05:22:39 #20797(main) <3j8rf1>; cfg; rspamd_map_parse_backend: map '/var/lib/rspamd/dmarc_whitelist.inc.local' is not found, but it can be loaded automatically later
2022-11-01 05:22:39 #20797(main) <3j8rf1>; cfg; rspamd_map_parse_backend: map '/etc/rspamd/local.d/maps.d/spf_dkim_whitelist.inc.local' is not found, but it can be loaded automatically later
2022-11-01 05:22:39 #20797(main) <3j8rf1>; cfg; rspamd_map_parse_backend: map '/var/lib/rspamd/spf_dkim_whitelist.inc.local' is not found, but it can be loaded automatically later
2022-11-01 05:22:39 #20797(main) <3j8rf1>; cfg; rspamd_map_parse_backend: map '/etc/rspamd/local.d/maps.d/dkim_whitelist.inc.local' is not found, but it can be loaded automatically later
2022-11-01 05:22:39 #20797(main) <3j8rf1>; cfg; rspamd_map_parse_backend: map '/var/lib/rspamd/dkim_whitelist.inc.local' is not found, but it can be loaded automatically later
2022-11-01 05:22:39 #20797(main) <3j8rf1>; cfg; rspamd_map_parse_backend: map '/etc/rspamd/maps.d/dkim_whitelist.inc' is not found, but it can be loaded automatically later
2022-11-01 05:22:39 #20797(main) <3j8rf1>; cfg; rspamd_init_lua_filters: init lua module whitelist from /usr/share/rspamd/plugins/whitelist.lua; digest: 093d6d1351
2022-11-01 05:22:39 #20797(main) rspamd_url_init: start compiling of 9628 TLD suffixes; it might take a long time
2022-11-01 05:23:11 #20823(main) lua; lua_cfg_transform.lua:161: group excessb64 has no symbols
2022-11-01 05:23:11 #20823(main) lua; lua_cfg_transform.lua:161: group excessqp has no symbols
2022-11-01 05:23:11 #20823(main) <>; lua; lua_cfg_transform.lua:519: enable options.check_all_filters for neural network
2022-11-01 05:23:11 #20823(main) <>; lua; lua_cfg_transform.lua:577: converted surbl rules to rbl rules
2022-11-01 05:23:11 #20823(main) <>; lua; lua_cfg_transform.lua:591: converted emails rules to rbl rules
2022-11-01 05:23:11 #20823(main) cfg; rspamd_rcl_maybe_apply_lua_transform: configuration has been transformed in Lua
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_config_set_action_score: action add header has been already registered with priority 0, override it with new priority: 0, old score: nan
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_config_set_action_score: action greylist has been already registered with priority 0, override it with new priority: 0, old score: nan
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_config_set_action_score: action reject has been already registered with priority 0, override it with new priority: 0, old score: nan
2022-11-01 05:23:11 #20823(main) rspamd_regexp_library_init: pcre2 is compiled with JIT for x86 64bit (little endian + unaligned)
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; lua_redis.lua:574: use default Redis settings for neural
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; init.lua:58: controller plugin maps; register webui path query_specific
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; init.lua:58: controller plugin maps; register webui path list
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; init.lua:58: controller plugin maps; register webui path query_json
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; init.lua:58: controller plugin neural; register webui path learn
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; init.lua:58: controller plugin selectors; register webui path check_message
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; init.lua:58: controller plugin selectors; register webui path list_extractors
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; init.lua:58: controller plugin selectors; register webui path check_selector
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; init.lua:58: controller plugin selectors; register webui path list_transforms
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_language_detector_init: loaded 46 languages, 33122 trigrams
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; chartable_module_config: init internal chartable module
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; dkim_module_config: init internal dkim module
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_mime_expr_parse: added condition for regexp /\b[13LM][1-9A-Za-z]{25,34}\b/AL{sa_body}
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_mime_expr_parse: added condition for regexp /\b(?🙁?:[a-zA-Z]\w+🙂|(?:bc1))?[qpzry9x8gf2tvdw0s3jn54khce6mua7l]{14,}\b/AL{sa_body}
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; regexp_module_config: init internal regexp module, 122 regexp rules and 0 lua rules are loaded
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; fuzzy_parse_rule: added fuzzy rule FUZZY_UNKNOWN, key: ef43ae80cc8d, shingles_key: ef43ae80cc8d, algorithm: mum
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; fuzzy_check_module_config: init internal fuzzy_check module, 1 rules loaded
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; lua_redis.lua:574: use default Redis settings for antivirus
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_init_lua_filters: init lua module antivirus from /usr/share/rspamd/plugins/antivirus.lua; digest: 3ddf7457fe
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_init_lua_filters: init lua module arc from /usr/share/rspamd/plugins/arc.lua; digest: 42c908e22c
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_init_lua_filters: init lua module asn from /usr/share/rspamd/plugins/asn.lua; digest: 9130c6dd80
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_config_is_module_enabled: lua module aws_s3 is disabled in the configuration
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_init_lua_filters: init lua module bayes_expiry from /usr/share/rspamd/plugins/bayes_expiry.lua; digest: 8469f2c8e0
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_config_is_module_enabled: lua module bimi is disabled in the configuration
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; clickhouse.lua:1389: no servers are specified, disabling module
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_init_lua_filters: init lua module clickhouse from /usr/share/rspamd/plugins/clickhouse.lua; digest: 1ebf33df2b
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_config_is_module_enabled: lua module clustering is enabled but has not been configured
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_config_is_module_enabled: clustering disabling unconfigured lua module
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_config_is_module_enabled: lua module dcc is disabled in the configuration
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; lua_maps.lua:149: reuse url for complex map definition chqbixcj: DKIM signing networks
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_init_lua_filters: init lua module dkim_signing from /usr/share/rspamd/plugins/dkim_signing.lua; digest: ef1e58a0f6
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_init_lua_filters: init lua module dmarc from /usr/share/rspamd/plugins/dmarc.lua; digest: 82e0ec100a
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_config_is_module_enabled: lua module dynamic_conf is enabled but has not been configured
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_config_is_module_enabled: dynamic_conf disabling unconfigured lua module
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; lua_redis.lua:574: use default Redis settings for elastic
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; elastic.lua:479: no servers are specified, disabling module
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_init_lua_filters: init lua module elastic from /usr/share/rspamd/plugins/elastic.lua; digest: 98232c69f3
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_init_lua_filters: init lua module emails from /usr/share/rspamd/plugins/emails.lua; digest: 7ecf38ef46
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_config_is_module_enabled: lua module external_relay is disabled in the configuration
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; lua_redis.lua:574: use default Redis settings for external_services
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_init_lua_filters: init lua module external_services from /usr/share/rspamd/plugins/external_services.lua; digest: dcba1920cb
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_init_lua_filters: init lua module force_actions from /usr/share/rspamd/plugins/force_actions.lua; digest: 8d4a7db39e
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_init_lua_filters: init lua module forged_recipients from /usr/share/rspamd/plugins/forged_recipients.lua; digest: 93694c50f3
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_config_is_module_enabled: lua module fuzzy_collect is enabled but has not been configured
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_config_is_module_enabled: fuzzy_collect disabling unconfigured lua module
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_map_parse_backend: map '/etc/rspamd/local.d/greylist-whitelist-domains.inc' is not found, but it can be loaded automatically later
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_map_parse_backend: map '/etc/rspamd/local.d/maps.d/greylist-whitelist-domains.inc' is not found, but it can be loaded automatically later
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; lua_redis.lua:574: use default Redis settings for greylist
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_init_lua_filters: init lua module greylist from /usr/share/rspamd/plugins/greylist.lua; digest: 88e764a28b
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_init_lua_filters: init lua module hfilter from /usr/share/rspamd/plugins/hfilter.lua; digest: 0b5505de7e
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; lua_redis.lua:574: use default Redis settings for history_redis
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_init_lua_filters: init lua module history_redis from /usr/share/rspamd/plugins/history_redis.lua; digest: e8431001f0
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_config_is_module_enabled: lua module http_headers is disabled in the configuration
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_config_is_module_enabled: lua module ip_score is enabled but has not been configured
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_config_is_module_enabled: ip_score disabling unconfigured lua module
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_init_lua_filters: init lua module maillist from /usr/share/rspamd/plugins/maillist.lua; digest: 90b48e62f8
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_config_is_module_enabled: lua module maps_stats is enabled but has not been configured
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_config_is_module_enabled: maps_stats disabling unconfigured lua module
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_init_lua_filters: init lua module metadata_exporter from /usr/share/rspamd/plugins/metadata_exporter.lua; digest: 2faafecb7a
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_init_lua_filters: init lua module metric_exporter from /usr/share/rspamd/plugins/metric_exporter.lua; digest: e94b1e4543
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_map_parse_backend: map '/etc/rspamd/local.d/maps.d/mid.inc' is not found, but it can be loaded automatically later
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_map_parse_backend: map '/etc/rspamd/local.d/mid.inc' is not found, but it can be loaded automatically later
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_init_lua_filters: init lua module mid from /usr/share/rspamd/plugins/mid.lua; digest: bd54b41b55
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; milter_headers.lua:683: active routines [x-spamd-result,x-rspamd-server,x-rspamd-queue-id,remove-spam-flag]
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_init_lua_filters: init lua module milter_headers from /usr/share/rspamd/plugins/milter_headers.lua; digest: 8c5248dbe9
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_map_parse_backend: map '/etc/rspamd/local.d/maps.d/mime_types.inc.local' is not found, but it can be loaded automatically later
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_map_parse_backend: map '/var/lib/rspamd/mime_types.inc.local' is not found, but it can be loaded automatically later
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_init_lua_filters: init lua module mime_types from /usr/share/rspamd/plugins/mime_types.lua; digest: 801533eeb1
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; lua_redis.lua:574: use default Redis settings for multimap
2022-11-01 05:23:11 #20823(main) <fdp86m>; map; rspamd_map_add: added map https://maps.rspamd.com/freemail/free.txt.zst
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; multimap.lua:1246: added multimap rule: freemail_replyto (header)
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; lua_maps.lua:127: reuse url for https://maps.rspamd.com/freemail/free.txt.zst(hash)
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; multimap.lua:1246: added multimap rule: freemail_to (header)
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; multimap.lua:1246: added multimap rule: freemail_envfrom (from)
2022-11-01 05:23:11 #20823(main) <k8f914>; map; rspamd_map_add: added map https://maps.rspamd.com/freemail/disposable.txt.zst
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; multimap.lua:1246: added multimap rule: disposable_from (header)
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; lua_maps.lua:127: reuse url for https://maps.rspamd.com/freemail/disposable.txt.zst(hash)
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; multimap.lua:1246: added multimap rule: disposable_envfrom (from)
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; multimap.lua:1246: added multimap rule: disposable_replyto (header)
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; multimap.lua:1246: added multimap rule: disposable_envrcpt (rcpt)
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; multimap.lua:1246: added multimap rule: disposable_cc (header)
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; multimap.lua:1246: added multimap rule: freemail_cc (header)
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; multimap.lua:1246: added multimap rule: freemail_from (header)
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; multimap.lua:1246: added multimap rule: disposable_to (header)
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; multimap.lua:1246: added multimap rule: freemail_envrcpt (rcpt)
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_init_lua_filters: init lua module multimap from /usr/share/rspamd/plugins/multimap.lua; digest: 2ea8fd7bac
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_config_is_module_enabled: lua module mx_check is disabled in the configuration
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; neural.lua:932: register ann rule default
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_init_lua_filters: init lua module neural from /usr/share/rspamd/plugins/neural.lua; digest: 765c449650
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_init_lua_filters: init lua module once_received from /usr/share/rspamd/plugins/once_received.lua; digest: 77be661bef
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_config_is_module_enabled: lua module p0f is disabled in the configuration
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_map_parse_backend: map '/etc/rspamd/local.d/maps.d/phishing_whitelist.inc' is not found, but it can be loaded automatically later
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_map_parse_backend: map '/etc/rspamd/local.d/phishing_whitelist.inc' is not found, but it can be loaded automatically later
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_map_parse_backend: map '/etc/rspamd/local.d/maps.d/redirectors.inc' is not found, but it can be loaded automatically later
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_map_parse_backend: map '/etc/rspamd/local.d/redirectors.inc' is not found, but it can be loaded automatically later
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_init_lua_filters: init lua module phishing from /usr/share/rspamd/plugins/phishing.lua; digest: 411728d0b2
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; lua_redis.lua:565: NOT using default redis server for module ratelimit: it is disabled
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; ratelimit.lua:865: no servers are specified, disabling module
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_init_lua_filters: init lua module ratelimit from /usr/share/rspamd/plugins/ratelimit.lua; digest: c6c0cf1fdf
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_map_parse_backend: map '/etc/rspamd/local.d/maps.d/surbl-whitelist.inc.local' is not found, but it can be loaded automatically later
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_map_parse_backend: map '/var/lib/rspamd/surbl-whitelist.inc.local' is not found, but it can be loaded automatically later
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; rbl.lua:1030: added URL whitelist for RBL SEM_URIBL_UNKNOWN
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; rbl.lua:1083: added rbl rule SEM_URIBL_UNKNOWN: checks: alive,dkim,emails,urls
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; lua_maps.lua:149: reuse url for complex map definition p1tsamp7: RBL url whitelist for SURBL_MULTI
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; rbl.lua:1030: added URL whitelist for RBL SURBL_MULTI
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; rbl.lua:1083: added rbl rule SURBL_MULTI: checks: alive,helo,dkim,emails,replyto,urls,rdns
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; rbl.lua:1083: added rbl rule RBL_SEM: checks: alive,user,local,ip
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; rbl.lua:1083: added rbl rule RBL_SENDERSCORE: checks: alive,user,local,ip
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; rbl.lua:1083: added rbl rule RBL_SEM_IPV6: checks: alive,user,local,ip
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; lua_maps.lua:149: reuse url for complex map definition p1tsamp7: RBL url whitelist for DBL
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; rbl.lua:1030: added URL whitelist for RBL DBL
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; rbl.lua:1083: added rbl rule DBL: checks: alive,helo,dkim,emails,replyto,urls,rdns
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; rbl.lua:1205: disable rbl "SPAMHAUS_ZEN_URIBL"
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; rbl.lua:1083: added rbl rule RBL_VIRUSFREE_UNKNOWN: checks: alive,user,local,ip
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; rbl.lua:1083: added rbl rule BLOCKLISTDE: checks: alive,user,local,ip,received
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; lua_maps.lua:149: reuse url for complex map definition p1tsamp7: RBL url whitelist for DWL_DNSWL
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; rbl.lua:1030: added URL whitelist for RBL DWL_DNSWL
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; rbl.lua:1083: added rbl rule DWL_DNSWL: checks: alive,user,local,dkim
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; rbl.lua:1083: added rbl rule RCVD_IN_DNSWL: checks: alive,user,local,ip,received
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; rbl.lua:1083: added rbl rule SPAMHAUS: checks: alive,user,local,ip,received
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; lua_maps.lua:149: reuse url for complex map definition p1tsamp7: RBL url whitelist for RSPAMD_URIBL
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; rbl.lua:1030: added URL whitelist for RBL RSPAMD_URIBL
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; rbl.lua:1083: added rbl rule RSPAMD_URIBL: checks: alive,dkim,emails,urls
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; lua_maps.lua:149: reuse url for complex map definition p1tsamp7: RBL url whitelist for RSPAMD_EMAILBL
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; rbl.lua:1030: added URL whitelist for RBL RSPAMD_EMAILBL
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; rbl.lua:1083: added rbl rule RSPAMD_EMAILBL: checks: alive,emails,replyto
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; lua_maps.lua:149: reuse url for complex map definition p1tsamp7: RBL url whitelist for SEM_URIBL_FRESH15_UNKNOWN
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; rbl.lua:1030: added URL whitelist for RBL SEM_URIBL_FRESH15_UNKNOWN
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; rbl.lua:1083: added rbl rule SEM_URIBL_FRESH15_UNKNOWN: checks: alive,dkim,emails,urls
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; lua_maps.lua:149: reuse url for complex map definition p1tsamp7: RBL url whitelist for MSBL_EBL
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; rbl.lua:1030: added URL whitelist for RBL MSBL_EBL
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; rbl.lua:1083: added rbl rule MSBL_EBL: checks: alive,emails,replyto
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; lua_maps.lua:149: reuse url for complex map definition p1tsamp7: RBL url whitelist for URIBL_MULTI
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; rbl.lua:1030: added URL whitelist for RBL URIBL_MULTI
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; rbl.lua:1083: added rbl rule URIBL_MULTI: checks: alive,helo,dkim,emails,replyto,urls,rdns
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; rbl.lua:1083: added rbl rule MAILSPIKE: checks: alive,user,local,ip
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; rbl.lua:1083: added rbl rule RBL_NIXSPAM: checks: alive,user,local,ip
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_init_lua_filters: init lua module rbl from /usr/share/rspamd/plugins/rbl.lua; digest: 98accc9edc
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; lua_redis.lua:574: use default Redis settings for replies
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_init_lua_filters: init lua module replies from /usr/share/rspamd/plugins/replies.lua; digest: f751f34289
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; lua_redis.lua:574: use default Redis settings for reputation
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_init_lua_filters: init lua module reputation from /usr/share/rspamd/plugins/reputation.lua; digest: 891ce52cea
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_config_is_module_enabled: lua module rspamd_update is disabled in the configuration
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_init_lua_filters: init lua module settings from /usr/share/rspamd/plugins/settings.lua; digest: 458e8f57f4
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_init_lua_filters: init lua module spamassassin from /usr/share/rspamd/plugins/spamassassin.lua; digest: 17dbffbfa8
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_config_is_module_enabled: lua module spamtrap is disabled in the configuration
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_init_lua_filters: init lua module spf from /usr/share/rspamd/plugins/spf.lua; digest: 2c5b224632
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; trie.lua:167: no tries defined
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_init_lua_filters: init lua module trie from /usr/share/rspamd/plugins/trie.lua; digest: eeaf4aab9f
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; lua_redis.lua:574: use default Redis settings for url_redirector
2022-11-01 05:23:11 #20823(main) <ifhd34>; lua; url_redirector.lua:339: no redirector_hosts_map option is specified, disabling module
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_init_lua_filters: init lua module url_redirector from /usr/share/rspamd/plugins/url_redirector.lua; digest: e000e2e07d
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_map_parse_backend: map '/etc/rspamd/local.d/maps.d/spf_whitelist.inc.local' is not found, but it can be loaded automatically later
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_map_parse_backend: map '/var/lib/rspamd/spf_whitelist.inc.local' is not found, but it can be loaded automatically later
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_map_parse_backend: map '/etc/rspamd/maps.d/spf_whitelist.inc' is not found, but it can be loaded automatically later
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_map_parse_backend: map '/etc/rspamd/local.d/maps.d/dkim_whitelist.inc.local' is not found, but it can be loaded automatically later
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_map_parse_backend: map '/var/lib/rspamd/dkim_whitelist.inc.local' is not found, but it can be loaded automatically later
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_map_parse_backend: map '/etc/rspamd/maps.d/dkim_whitelist.inc' is not found, but it can be loaded automatically later
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_map_parse_backend: map '/etc/rspamd/local.d/maps.d/dmarc_whitelist.inc.local' is not found, but it can be loaded automatically later
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_map_parse_backend: map '/var/lib/rspamd/dmarc_whitelist.inc.local' is not found, but it can be loaded automatically later
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_map_parse_backend: map '/etc/rspamd/local.d/maps.d/spf_dkim_whitelist.inc.local' is not found, but it can be loaded automatically later
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_map_parse_backend: map '/var/lib/rspamd/spf_dkim_whitelist.inc.local' is not found, but it can be loaded automatically later
2022-11-01 05:23:11 #20823(main) <ifhd34>; cfg; rspamd_init_lua_filters: init lua module whitelist from /usr/share/rspamd/plugins/whitelist.lua; digest: 093d6d1351
2022-11-01 05:23:11 #20823(main) rspamd_url_init: start compiling of 9628 TLD suffixes; it might take a long time
