In store it appears installed but when I try to start the service, it says:
Sorry, something went wrong:
raise NotFound()
chunked=chunked,
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connectionpool.py", line 394, in make_request
conn.request(method, url, **httplib_request_kw)
File "/www/server/panel/pyenv/lib/python3.7/http/client.py", line 1262, in request
self.send_request(method, url, body, headers, encode_chunked)
File "/www/server/panel/pyenv/lib/python3.7/http/client.py", line 1308, in send_request
self.endheaders(body, encode_chunked=encode_chunked)
File "/www/server/panel/pyenv/lib/python3.7/http/client.py", line 1257, in endheaders
self.send_output(message_body, encode_chunked=encode_chunked)
File "/www/server/panel/pyenv/lib/python3.7/http/client.py", line 1028, in send_output
self.send(msg)
File "/www/server/panel/pyenv/lib/python3.7/http/client.py", line 968, in send
self.connect()
File "/www/server/panel/pyenv/lib/python3.7/site-packages/docker/transport/unixconn.py", line 43, in connect
sock.connect(self.unix_socket)
File "/www/server/panel/pyenv/lib/python3.7/site-packages/gevent/socketcommon.py", line 628, in connect
raise _SocketError(result, strerror(result))
FileNotFoundError: [Errno 2] No such file or directory
timeout=timeout
method, url, error=e, _pool=self, _stacktrace=sys.exc_info()[2]
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/util/retry.py", line 532, in increment
raise six.reraise(type(error), error, _stacktrace)
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/packages/six.py", line 769, in reraise
chunked=chunked,
self.send(msg)
self.connect()
urllib3.exceptions.ProtocolError: ('Connection aborted.', FileNotFoundError(2, 'No such file or directory'))
File "class/panelPlugin.py", line 2141, in a
return eval(execStr)
File "", line 1, in
File "/www/server/panel/plugin/docker/docker_main.py", line 663, in service_admin
for container in self.__docker.containers.list(all=True):
File "/www/server/panel/pyenv/lib/python3.7/site-packages/docker/models/containers.py", line 937, in list
since=since)
File "/www/server/panel/pyenv/lib/python3.7/site-packages/docker/api/container.py", line 211, in containers
res = self.result(self.get(u, params=params), True)
File "/www/server/panel/pyenv/lib/python3.7/site-packages/docker/utils/decorators.py", line 46, in inner
return f(self, *args, **kwargs)
File "/www/server/panel/pyenv/lib/python3.7/site-packages/docker/api/client.py", line 230, in get
return self.get(url, **self.set_request_timeout(kwargs))
File "/www/server/panel/pyenv/lib/python3.7/site-packages/requests/sessions.py", line 555, in get
return self.request('GET', url, **kwargs)
File "/www/server/panel/pyenv/lib/python3.7/site-packages/requests/adapters.py", line 498, in send
raise ConnectionError(err, request=request)
requests.exceptions.ConnectionError: ('Connection aborted.', FileNotFoundError(2, 'No such file or directory'))
