aaPanel_Kern aaP_leon6077 Does the firewall open related ports? Do you to map ports when Docker is created?
aaP_leon6077 I opend the ports, yes. first how do i change the error in discourse with default web ports 80/443 how to map the ports? Using Ngnix
aaPanel_Kern aaP_leon6077 the host uses other ports, the container can default, such as: -p 81:80 -p 9443: 443 among them, 81, 9443 Can the host be accessed? curl http://container:port
aaP_leon6077 i used (tryd) port 90 and 543 didnt work like that Also i would like to use a specific db not a self generated ..
aaP_cinemanovels aaPanel_Kern how we fill this details to install Repository Link https://github.com/discourse/discourse-air
aaPanel_Kern https://meta.discourse.org/t/installing-a-theme-or-theme-component/63682 Hello, please refer to the official installation document aaP_cinemanovels
