aaP_pr Good afternoon! After restarting the server, I can not enter the panel https://site:7800/ Didn't change the address, just rebooted. 404 Not Found nginx What's wrong? And how to enter the panel?
aaPanel_Kern aaP_pr Hello, please use the full link to access the panel. You can use the ssh tool to execute commands to view the default links: bt 14
aaP_pr aaPanel_Kern I enter bt, I look at the path, follow it and get to a blank page 404 Not Found nginx
aaPanel_Kern aaP_pr Is it possible to login to the panel? If you can, please add a security entry directly in the settings Otherwise, use the command Add to replace aaaaaa with your security portal: echo "/aaaaa" >> /www/server/panel/data/admin_path.pl && bt 1
