Im facing trouble connecting to aapanel admin site
What i did:
1) Try to lookout for the available port by running in terminal firewall-cmd --list-all
2) But then it said "command 'firewall-cmd' not found, but can be installed with: apt install firewalld , so i run the code
3) After install, i test and can't access to server using FileZilla
4) I read an aapanel forum said the same issue and the solution is to stop firewalld so i ran the command systemctl stop firewalld
5) Then can connect with FileZilla, but SYS Firewall when opened keeps loading
6) So i reboot server by running sudo reboot
7) Then after rebooting, the server cannot be access and only shows the terminal. But can successfully ping the ipaddress
Please help aaPanel_Kern @aaPanel_Jose
