Hi,
its not possible to install nginx.
Logfile:
`config.status: creating libpcre16.pc
config.status: creating libpcre32.pc
config.status: creating libpcreposix.pc
config.status: creating libpcrecpp.pc
config.status: creating pcre-config
config.status: creating pcre.h
config.status: creating pcre_stringpiece.h
config.status: creating pcrecpparg.h
config.status: creating config.h
config.status: executing depfiles commands
config.status: executing libtool commands
config.status: executing script-chmod commands
config.status: executing delete-old-chartables commands
pcre-8.43 configuration summary:
Install prefix .................. : /usr/local
C preprocessor .................. : cc -E
C compiler ...................... : cc
C++ preprocessor ................ : g++ -E
C++ compiler .................... : g++
Linker .......................... : /bin/ld -m elf_x86_64
C preprocessor flags ............ :
C compiler flags ................ : -O2 -fomit-frame-pointer -pipe -fvisibility=hidden
C++ compiler flags .............. : -O2 -fvisibility=hidden -fvisibility-inlines-hidden
Linker flags .................... :
Extra libraries ................. :
Build 8 bit pcre library ........ : yes
Build 16 bit pcre library ....... : no
Build 32 bit pcre library ....... : no
Build C++ library ............... : yes
Enable JIT compiling support .... : no
Enable UTF-8/16/32 support ...... : no
Unicode properties .............. : no
Newline char/sequence ........... : lf
\R matches only ANYCRLF ......... : no
EBCDIC coding ................... : no
EBCDIC code for NL .............. : n/a
Rebuild char tables ............. : no
Use stack recursion ............. : yes
POSIX mem threshold ............. : 10
Internal link size .............. : 2
Nested parentheses limit ........ : 250
Match limit ..................... : 10000000
Match limit recursion ........... : MATCH_LIMIT
Build shared libs ............... : no
Build static libs ............... : yes
Use JIT in pcregrep ............. : no
Buffer size for pcregrep ........ : 20480
Link pcregrep with libz ......... : no
Link pcregrep with libbz2 ....... : no
Link pcretest with libedit ...... : no
Link pcretest with libreadline .. : no
Valgrind support ................ : no
Code coverage ................... : no
cd /www/server/nginx/src/openssl \
&& if [ -f Makefile ]; then make clean; fi \
&& ./config --prefix=/www/server/nginx/src/openssl/.openssl no-shared no-threads \
&& make \
&& make install_sw LIBDIR=lib
Operating system: x86_64-whatever-linux2
Can't locate File/Path.pm in @INC (@INC contains: /www/server/nginx/src/openssl/util/perl /usr/local/lib64/perl5 /usr/local/share/perl5 /usr/lib64/perl5/vendor_perl /usr/share/perl5/vendor_perl /usr/lib64/perl5 /usr/share/perl5 .) at ./Configure line 19.
BEGIN failed--compilation aborted at ./Configure line 19.
This system (linux-x86_64) is not supported. See file INSTALL for details.
make[1]: *** [/www/server/nginx/src/openssl/.openssl/include/openssl/ssl.h] Error 1
make[1]: Leaving directory /www/server/nginx/src'
make: *** [build] Error 2
make -f objs/Makefile install
make[1]: Entering directory/www/server/nginx/src'
&& make \
make[1]: Leaving directory `/www/server/nginx/src'
make: *** [install] Error 2
CentOS Linux release 7.9.2009 (Core)
Bit:64 Mem:990M Core:1 gcc:4.8.5 cmake:2.8.12.2
Linux 3.10.0-1160.80.1.el7.x86_64 x86_64
ERROR: nginx-1.21.4 installation failed.
安装失败,请截图以上报错信息发帖至论坛www.bt.cn/bbs求助
或手机访问以下链接、扫码联系企业微信技术求助
帖子或企业微信注明企业版用户,将获得极速响应技术支持
|-Successify ---Script execution completed---`
