aaP_runqubit
Hello, sending to gmail requires Add SSL, it is best to let the network provider make the PTRRDNS record of ip
At the same time, check the postfix configuration, which can be viewed in the server status
Put:
Change to:
or
Unable to send dkim headers
Prompt for permission issues:
systemctl restart rspamd
Use this website to check whether the records of DKIM and SPF are correct?
https://www.dmarcanalyzer.com/dkim/dkim-checker/
https://dnschecker.org/spf-record-validation.php
https://www.mail-tester.com/
