carlita Just a heads-up. I can confirm that in my 2 servers with this panel, the ssh terminal is not working. It connects fine, but just a black screen Was working fine in 6.8.26 Thanks!
aaPanel_florevit an got it fixed to directly overwrite all again dont update to beta because its not go work when go back to stable version aaPanel installation script https://www.aapanel.com/new/download.html Centos yum install -y wget && wget -O install.sh http://www.aapanel.com/script/install_6.0_en.sh && bash install.sh aapanel Copy Ubuntu/Deepin wget -O install.sh http://www.aapanel.com/script/install-ubuntu_6.0_en.sh && sudo bash install.sh aapanel Copy Debian wget -O install.sh http://www.aapanel.com/script/install-ubuntu_6.0_en.sh && bash install.sh aapanel Copy its changed password so saving the details you get new
carlita @aaPanel_florevit thanks for responding! Not sure if I understand. I have a working server, isn't that command to install all from scratch? Should I roll back to 6.8.26? If so, how? Thanks!
aaPanel_florevit carlita you can run this line for the OS you use its only reset everthing like a upgrade folow the things what you see and after its refix it with new pasword only its set all back to latest stable version and terminal would work after. itwould not work back if you on beta version and revert back to stable version
aaP_admin0 Hi, I experienced the same thing after updating to the latest stable version v6.8.27 Please fix it with the latest update
aaP_admin0 thanks god I almost did a reinstall ok, let's wait for the next update thank you aaPanel_Kern
aaPanel_Kern aaP_admin0 Hello, this problem has been fixed, click "Fix" on the home page to fix it, wait for a moment and try again.
carlita @aaPanel_Kern You guys are the best!!! it works! Thanks a lot for all the hard and excellent work! 😀
