asaddon
Hello, Access using http is hijacked. You need to enable SSL and then access using https
you can open Panel SSL by executing the overwrite installation command. It will also be updated to the latest version.
Overwriting the installation will not lose data, only change the aapanel username and password.
There is currently no way to directly enable panel SSL
You are advised to perform this operation after the server backs up snapshots
Centos :
yum install -y wget && wget -O install.sh http://www.aapanel.com/script/install_6.0_en.sh && bash install.sh aapanel
Ubuntu/Deepin :
wget -O install.sh http://www.aapanel.com/script/install-ubuntu_6.0_en.sh && sudo bash install.sh aapanel
Debian :
wget -O install.sh http://www.aapanel.com/script/install-ubuntu_6.0_en.sh && bash install.sh aapanel
Do you need to enable the panel SSl ? (yes/n): yes
Use privacy mode if you cannot access the panel browser
