aaPanel_Kern aaP_gorgeious1 Hello, is the problem solved? If not, can you try to delete that user and add another user?
aaP_gorgeious1 aaPanel_Kern not solved yet.. is there any need to modify the password of database and then change it in codychat files also?
aaP_gorgeious1 aaPanel_Kern i tried to change the password but after changing password the site showed blank page
aaPanel_Kern aaP_gorgeious1 First check whether the password can be logged in normally after modification, and then you need to modify the database configuration file of the site
aaPanel_Kern aaP_gorgeious1 Not sure about your website program Suggest to consult the program developer
aaP_gorgeious1 aaPanel_Kern oh actually its a codychatroom site. i handed over to a developer but he is not more trusthworthy .
aaP_gorgeious1 aaPanel_Kern Thank You for your help. i found the configuration file. by changing the password. now it is working. Thank you again. problem solved
