just tried to run bt command, select 16 to repair panel
here is output:
`EXECUTING
Requirement already satisfied: cachelib in ./pyenv/lib/python3.7/site-packages (0.1.1)
WARNING: You are using pip version 20.3.3; however, version 23.0.1 is available.
You should consider upgrading via the '/www/server/panel/pyenv/bin/python3.7 -m pip install --upgrade pip' command.
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 3349 100 3349 0 0 4044 0 --:--:-- --:--:-- --:--:-- 4039
URL transformed to HTTPS due to an HSTS policy
--2023-03-02 21:32:57-- https://download.bt.cn/install/public.sh
Resolving download.bt.cn (download.bt.cn)... 116.10.184.219, 2001:19f0:7001:54fc:5400:2ff:fe9b:97f9
Connecting to download.bt.cn (download.bt.cn)|116.10.184.219|:443... connected.
Length: 4320 (4.2K) [application/octet-stream]
Saving to: ‘Tpublic.sh’
Tpublic.sh 100%[================================================================>] 4.22K --.-KB/s in 0s
2023-03-02 21:32:58 (671 MB/s) - ‘Tpublic.sh’ saved [4320/4320]
selecting download node...
curl: (7) Failed to connect to brandnew.aapanel.com port 443: Connection timed out
--2023-03-02 21:33:00-- https://node.aapanel.com/install/update/LinuxPanel_EN-6.8.27.zip
Resolving node.aapanel.com (node.aapanel.com)... 172.64.80.1, 2606:4700:130:436c:6f75:6466:6c61:7265
Connecting to node.aapanel.com (node.aapanel.com)|172.64.80.1|:443... failed: Connection timed out.
Connecting to node.aapanel.com (node.aapanel.com)|2606:4700:130:436c:6f75:6466:6c61:7265|:443... failed: Network is unreachable.
Failed to get update package, please update or contact aaPanel Operation`
