As you can see current status says off. when i try to start it says already started. Restart or reload says same thing.
here is execution log
make[1]: Entering directory '/root/pure-ftpd-1.0.49/src'
make[2]: Entering directory '/root/pure-ftpd-1.0.49/src'
/bin/mkdir -p '/www/server/pure-ftpd/bin'
/bin/install -c pure-statsdecode pure-pw pure-pwconvert '/www/server/pure-ftpd/bin'
/bin/mkdir -p '/www/server/pure-ftpd/sbin'
/bin/install -c pure-authd pure-certd pure-ftpd pure-ftpwho pure-mrtginfo pure-quotacheck pure-uploadscript '/www/server/pure-ftpd/sbin'
make[2]: Nothing to be done for 'install-data-am'.
make[2]: Leaving directory '/root/pure-ftpd-1.0.49/src'
make[1]: Leaving directory '/root/pure-ftpd-1.0.49/src'
Making install in man
make[1]: Entering directory '/root/pure-ftpd-1.0.49/man'
make[2]: Entering directory '/root/pure-ftpd-1.0.49/man'
make[2]: Nothing to be done for 'install-exec-am'.
/bin/mkdir -p '/www/server/pure-ftpd/share/man/man8'
/bin/install -c -m 644 pure-ftpd.8 pure-ftpwho.8 pure-mrtginfo.8 pure-uploadscript.8 pure-statsdecode.8 pure-quotacheck.8 pure-pw.8 pure-pwconvert.8 pure-authd.8 pure-certd.8 '/www/server/pure-ftpd/share/man/man8'
make[2]: Leaving directory '/root/pure-ftpd-1.0.49/man'
make[1]: Leaving directory '/root/pure-ftpd-1.0.49/man'
Making install in pam
make[1]: Entering directory '/root/pure-ftpd-1.0.49/pam'
make[2]: Entering directory '/root/pure-ftpd-1.0.49/pam'
make[2]: Leaving directory '/root/pure-ftpd-1.0.49/pam'
make[1]: Leaving directory '/root/pure-ftpd-1.0.49/pam'
Making install in gui
make[1]: Entering directory '/root/pure-ftpd-1.0.49/gui'
make[2]: Entering directory '/root/pure-ftpd-1.0.49/gui'
make[2]: Leaving directory '/root/pure-ftpd-1.0.49/gui'
make[1]: Leaving directory '/root/pure-ftpd-1.0.49/gui'
Making install in m4
make[1]: Entering directory '/root/pure-ftpd-1.0.49/m4'
make[2]: Entering directory '/root/pure-ftpd-1.0.49/m4'
make[2]: Leaving directory '/root/pure-ftpd-1.0.49/m4'
make[1]: Leaving directory '/root/pure-ftpd-1.0.49/m4'
make[1]: Entering directory '/root/pure-ftpd-1.0.49'
make[2]: Entering directory '/root/pure-ftpd-1.0.49'
/bin/mkdir -p '/www/server/pure-ftpd/share/doc/pure-ftpd'
/bin/install -c -m 644 FAQ README.LDAP README.MySQL README.PGSQL README.Configuration-File README.Virtual-Users README.Authentication-Modules README.TLS README.MacOS-X pure-ftpd.conf pureftpd.schema pureftpd-ldap.conf pureftpd-mysql.conf pureftpd-pgsql.conf '/www/server/pure-ftpd/share/doc/pure-ftpd'
make[2]: Leaving directory '/root/pure-ftpd-1.0.49'
make[1]: Leaving directory '/root/pure-ftpd-1.0.49'
Copy configure files...
--2023-03-10 21:00:16-- https://jp1-node.bt.cn/install/src/pure-config.pl
Resolving jp1-node.bt.cn (jp1-node.bt.cn)... 45.76.53.20
Connecting to jp1-node.bt.cn (jp1-node.bt.cn)|45.76.53.20|:443... connected.
Length: 4759 (4.6K) [application/x-perl]
Saving to: ‘pure-config.pl’
0K .... 100% 665M=0s
2023-03-10 21:00:16 (665 MB/s) - ‘pure-config.pl’ saved [4759/4759]
mkdir: cannot create directory ‘/www/server/pure-ftpd/etc’: File exists
--2023-03-10 21:00:16-- https://jp1-node.bt.cn/conf/pure-ftpd.conf
Length: 11468 (11K) [application/octet-stream]
Saving to: ‘/www/server/pure-ftpd/etc/pure-ftpd.conf’
0K .......... . 100% 12.6M=0.001s
2023-03-10 21:00:17 (12.6 MB/s) - ‘/www/server/pure-ftpd/etc/pure-ftpd.conf’ saved [11468/11468]
--2023-03-10 21:00:17-- https://jp1-node.bt.cn/init/pureftpd.init
Length: 1447 (1.4K) [application/octet-stream]
Saving to: ‘/etc/init.d/pure-ftpd’
0K . 100% 192M=0s
2023-03-10 21:00:17 (192 MB/s) - ‘/etc/init.d/pure-ftpd’ saved [1447/1447]
pureftpd.sh: line 75: StartUp: command not found
Starting pureftpd...
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
