I have just installed version 6.8.27 of aaPanel on Debian 11 from scratch.
Compared to previous versions (of aaPanel) I have noticed some panel malfunctions:
- after changing the default ports of aaPanel, SSH and FTP, the old ports (8888, 22, 21) cannot be deleted from the Security panel and the message "The system firewall is not open" appears.
I installed the SYS Firewall plugin, now I can block them but not delete them.
The SYS Firewall panel reports that it is in a "Running" state but in the Security risk the message: "Check whether the system firewall is enabled" keeps appearing.
I gave the command "systemctl status ufw" from the terminal but it replies with: "Unit ufw.service could not be found".
At this point I don't know if the firewall is enabled or not.
Can you give me some advice on what to do?
Ino
