Server OS: Centos7
PHP 7.4.28
The process of opening aaPanel is as follows, and the error code is as follows:
[root@fwe774zf23 ~]# bt
/usr/bin/bt: line 283: 2257 Segmentation fault $pythonV $panel_path/tools.py cli $1
[root@fwe774zf23 ~]# /etc/init.d/bt restart
Stopping Bt-Tasks... done
Stopping Bt-Panel... done
Starting Bt-Panel..../etc/init.d/bt: line 60: 2347 Segmentation fault nohup $panel_path/BT-Panel >> $log_file 2>&1
........failed
self.socket.sendall(response_body)
File "/www/server/panel/pyenv/lib/python3.7/site-packages/gevent/_socketcommon.py", line 699, in sendall
return _sendall(self, data_memory, flags)
File "/www/server/panel/pyenv/lib/python3.7/site-packages/gevent/_socketcommon.py", line 409, in _sendall
timeleft = __send_chunk(socket, chunk, flags, timeleft, end)
File "/www/server/panel/pyenv/lib/python3.7/site-packages/gevent/_socketcommon.py", line 338, in __send_chunk
data_sent += socket.send(chunk, flags)
File "/www/server/panel/pyenv/lib/python3.7/site-packages/gevent/_socketcommon.py", line 722, in send
return self._sock.send(data, flags)
BrokenPipeError: [Errno 32] Broken pipe
2023-03-17T09:41:16Z <Greenlet at 0x7f25073b54d0: _handle_and_close_when_done(<bound method WSGIServer.handle of <WSGIServer at , <bound method StreamServer.do_close of <WSGIServer, (<gevent._socket3.socket [closed] at 0x7f25072adec)> failed with BrokenPipeError
<gevent._socket3.socket at 0x7f25072adec0 object, fd=6, family=2, type=1, proto=0>: Invalid HTTP method: '\r\n'
<gevent._socket3.socket at 0x7f25072adec0 object, fd=6, family=2, type=1, proto=0>: Invalid HTTP method: 'JRMI\x00\x02K'
File "src/gevent/greenlet.py", line 906, in gevent._gevent_cgreenlet.Greenlet.run
File "/www/server/panel/pyenv/lib/python3.7/site-packages/gevent/baseserver.py", line 34, in _handle_and_close_when_done
return handle(*args_tuple)
File "/www/server/panel/pyenv/lib/python3.7/site-packages/gevent/pywsgi.py", line 1577, in handle
handler.handle()
done
Starting Bt-Tasks... /etc/init.d/bt: line 60: 2429 Segmentation fault nohup $panel_path/BT-Task >> $task_log_file 2>&1
failed
Starting Bt-Tasks... Bt-Tasks (pid 4153 7458 7459) already running
Starting Bt-Panel.... done
Starting Bt-Tasks... Bt-Tasks (pid 4153) already running
Starting Bt-Tasks... Bt-Tasks (pid 4153 7867 7868) already running
Starting Bt-Tasks... done
2022-12-15 18:22:26 [INFO]: Service started
2022-12-15 18:23:43 [INFO]: Service started
Starting Bt-Panel... Bt-Panel (pid 4300) already running
Starting Bt-Tasks... Bt-Tasks (pid 3946) already running
2023-04-04 19:35:18 [INFO]: Service started
Starting Bt-Panel... Bt-Panel (pid 4387) already running
Starting Bt-Tasks... Bt-Tasks (pid 4147) already running
so...
how to fix...
