aaP_chanuka789 actually, I have no such directory you mentioned above. I can't understand how to do that. please say how to do that step by step or do it for me. i really want this.
aaP_chanuka789 For this command , "openssl s_client -connect udeals.us:587 -starttls smtp" and for this command, "openssl s_client -connect mail.udeals.us:465 -starttls smtp" how can i fix this?
aaPanel_Kern Hello, it is recommended to check whether the mx record of your domain name is normal At the same time, the mx record used by the mail server cannot enable the cloudflare proxy aaP_chanuka789
aaP_chanuka789 in my server, there have only ssl-cert-snakeoil.pem, there is no ssl-cert-snakeoil.key on directory
aaPanel_Kern aaPanel_Kern Hello, it is recommended to check whether the mx record of your domain name is normal At the same time, the mx record used by the mail server cannot enable the cloudflare proxy aaP_chanuka789 Hello, let's solve this problem first
aaP_chanuka789 I deleted all other MX records and now I have only one MX record also i moved to Contabo DNS manager from Cloudflare using Change Nameservers. but still facing this problem
aaPanel_Kern Hello, please wait for the domain name to take effect. It takes a certain amount of time to change the content of the domain name to take effect aaP_chanuka789
aaPanel_Kern If the website is on the same server as the mail server, it is recommended to use 127.0.0.1 port for the connection address and use 25, and the website connects to the mail address to turn off tls/ssl
aaP_chanuka789 is this blacklist impact to this problem? this is my Ip address that shows in blaclist
aaPanel_Kern Check the website for suggestions. Different blacklists have different removal methods, and some cannot be removed
aaP_chanuka789 when i was in Cpanel this email worked well. if you can please fic this problem for me...
aaP_chanuka789 i did a SMTP test it also worked well. please fix this error for me. this is very important for me
aaPanel_Kern Do I need to use the domain name connected to the email address when checking? It is recommended to check whether the mailbox configuration of your website is correct aaP_chanuka789
