aaPanel_Kern aaP_towndev200 Hello, do not send out personal information. If you forget the user and password, you can use the ssh tool to execute commands to change: sudo bt 5 and sudo bt 6 https://www.aapanel.com/forum/d/13132-aapanel-cannot-log-in-and-cannot-be-accessed-workaround
bbws Hello, just click on forgot password and you will be redirected to the recovery tutorial on the forum. Below the image where you should click on your panel.
