First issue ๐
WARNING: You are using pip version 21.2.4; however, version 23.1.2 is available.
You should consider upgrading via the '/www/server/panel/pyenv/bin/python3.7 -m pip install --upgrade pip' command.
Second thing is :
Third thing is :
What should I do, Admin~ if u can, plz pm me, we can try to use [to desk/]
