aaPanel_Kern NayeemX Just set an unused port in the system. For Path, please select the directory where your project is stored.
NayeemX aaPanel_Kern can you set domain with this? my projects workss at ip:3366 but instate of ip i want to show the domain name
aaPanel_Kern Hello, it is recommended that you use mapping, which will map the relevant ports to the php project and use proxy mode to access the website. You only need to use the access domain name to access NayeemX
aaPanel_Kern NayeemX Hello, you can use the PHP project to create a new site to reverse proxy your project
aaPanel_Kern Enter any English for the agent name, and write your access address for the Target URL. NayeemX
