idflorin It's happening again "502 Bad Gateway Nginx" on the contact form. Restart Nginx, Restart Php 7.4. No effect. Restart VPS => "Your message has been sent." Restarting the VPS is not a solution.
[deleted] @aaPanel_Jose any ideas on troubleshooting and solving this issue? Emails are a must no matter server type.
idflorin [deleted] For me restarting the VPS solves the problem for a time. I'll keep testing to see how much time.
aaPanel_Jose idflorin please try to change /www/server/php/74/etc/php-fpm.conf and restart php request_terminate_timeout = 100 to request_terminate_timeout = 0
idflorin aaPanel_Jose Log in and test. Error is present after total VPS reboot. It was working fine for just about 2 hours after VPS reboot. Made the change request_terminate_timeout = 0 I restarted the PHP but the error is still present. 504 Gateway Time-out Rebooted Nginx and Php = the error is still present. 504 Gateway Time-out Error from PHP log: 2020/09/03 15:00:46 [error] 32236#0: *40509 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 109.103.221.35, server: electrichunter.com, request: "POST /contact HTTP/2.0", upstream: "fastcgi://unix:/tmp/php-cgi-74.sock", host: "www.electrichunter.com", referrer: "https://www.electrichunter.com/contact" VPS reboot => "Your message has been sent."
idflorin [deleted] 18 hour later after request_terminate_timeout = 0 + VPS reboot, Sendmail still works. I'll monitor this further and get back with feedback.
