aaP_mfhd I don't know what happened, the login button doesn't work and the control panel name went to "none"
aaPanel_Kern Hello, is it the same if I use the browser in incognito mode or change the browser? Try to use the command to check whether the user and password are normal: bt 14 aaP_mfhd
