After restart, i get this error
2020-09-01 21:53:04 0 [Note] InnoDB: Using Linux native AIO
2020-09-01 21:53:04 0 [Note] InnoDB: Mutexes and rw_locks use GCC atomic builtins
2020-09-01 21:53:04 0 [Note] InnoDB: Uses event mutexes
2020-09-01 21:53:04 0 [Note] InnoDB: Compressed tables use zlib 1.2.7
2020-09-01 21:53:04 0 [Note] InnoDB: Number of pools: 1
2020-09-01 21:53:04 0 [Note] InnoDB: Using SSE2 crc32 instructions
2020-09-01 21:53:04 0 [Note] mysqld: O_TMPFILE is not supported on /tmp (disabling future attempts)
2020-09-01 21:53:04 0 [Note] InnoDB: Initializing buffer pool, total size = 1G, instances = 8, chunk size = 128M
2020-09-01 21:53:04 0 [Note] InnoDB: Completed initialization of buffer pool
2020-09-01 21:53:04 0 [Note] InnoDB: If the mysqld execution user is authorized, page cleaner thread priority can be changed. See the man page of setpriority().
2020-09-01 21:53:05 0 [Note] InnoDB: Starting crash recovery from checkpoint LSN=144282911586
2020-09-01 21:53:05 0 [ERROR] InnoDB: Database page corruption on disk or a failed file read of tablespace innodb_system page [page id: space=0, page number=351]. You may have to recover from a backup.
2020-09-01 21:53:05 0 [Note] InnoDB: Page dump in ascii and hex (16384 bytes):
InnoDB: End of page dump
2020-09-01 21:53:05 0 [Note] InnoDB: Uncompressed page, stored checksum in field1 1555871297, calculated checksums for field1: crc32 1555871297, innodb 2495496133, page type 2 == UNDO LOG.none 3735928559, stored checksum in field2 1105759478, calculated checksums for field2: crc32 1555871297, innodb 1575272319, none 3735928559, page LSN 33 2548987875, low 4 bytes of LSN at page end 2548986805, page number (if stored to page already) 351, space id (if created with >= MySQL-4.1.1 and stored already) 0
InnoDB: Page may be an undo log page
2020-09-01 21:53:05 0 [Note] InnoDB: It is also possible that your operating system has corrupted its own file cache and rebooting your computer removes the error. If the corrupt page is an index page. You can also try to fix the corruption by dumping, dropping, and reimporting the corrupt table. You can use CHECK TABLE to scan your table for corruption. Please refer to https://mariadb.com/kb/en/library/innodb-recovery-modes/ for information about forcing recovery.
200901 21:53:05 [ERROR] mysqld got signal 11 ;
This could be because you hit a bug. It is also possible that this binary
or one of the libraries it was linked against is corrupt, improperly built,
or misconfigured. This error can also be caused by malfunctioning hardware.
To report this bug, see https://mariadb.com/kb/en/reporting-bugs
We will try our best to scrape up some info that will hopefully help
diagnose the problem, but since we have already crashed,
something is definitely wrong and this may fail.
Server version: 10.4.8-MariaDB-log
key_buffer_size=536870912
read_buffer_size=2097152
max_used_connections=0
max_threads=502
thread_count=0
It is possible that mysqld could use up to
key_buffer_size + (read_buffer_size + sort_buffer_size)*max_threads = 2592793 K bytes of memory
Hope that's ok; if not, decrease some variables in the equation.
Thread pointer: 0x0
Attempting backtrace. You can use the following information to find out
where mysqld died. If you see no messages after this, something went
terribly wrong...
stack_bottom = 0x0 thread_stack 0x60000
/www/server/mysql/bin/mysqld(my_print_stacktrace+0x29)[0x555a2612d1b9]
mysys/stacktrace.c:270(my_print_stacktrace)[0x555a25c5544f]
sigaction.c:0(__restore_rt)[0x2b65a71db630]
/www/server/mysql/bin/mysqld(+0xb1754d)[0x555a25eee54d]
log/log0recv.cc:2122(recv_recover_corrupt_page(page_id_t))[0x555a2600785a]
buf/buf0buf.cc:6199(buf_page_io_complete(buf_page_t*, bool, bool))[0x555a2602459f]
buf/buf0rea.cc:205(buf_read_page_low(dberr_t*, bool, unsigned long, unsigned long, page_id_t, unsigned long, bool, bool))[0x555a2602502f]
include/sync0types.h:1129(simple_counter<unsigned long>::add(unsigned long))[0x555a260095ac]
buf/buf0buf.cc:4439(buf_page_get_gen(page_id_t, unsigned long, unsigned long, buf_block_t*, unsigned long, char const*, unsigned int, mtr_t*, dberr_t*))[0x555a25fc4c1b]
include/trx0undo.ic:118(trx_undo_page_get)[0x555a25fb24e8]
trx/trx0rseg.cc:430(trx_undo_lists_init)[0x555a25fbeb05]
trx/trx0trx.cc:744(trx_lists_init_at_db_start())[0x555a25f8e91b]
srv/srv0start.cc:1891(srv_start(bool))[0x555a25e93c58]
handler/ha_innodb.cc:4261(innodb_init(void*))[0x555a25c583d1]
sql/handler.cc:557(ha_initialize_handlerton(st_plugin_int*))[0x555a25a732b8]
sql/sql_plugin.cc:1438(plugin_initialize(st_mem_root*, st_plugin_int*, int*, char**, bool))[0x555a25a74372]
sql/sql_plugin.cc:1720(plugin_init(int*, char**, int))[0x555a259a9860]
sql/mysqld.cc:5203(init_server_components())[0x555a259ae342]
/lib64/libc.so.6(__libc_start_main+0xf5)[0x2b65a8f87555]
/www/server/mysql/bin/mysqld(+0x5cc047)[0x555a259a3047]
The manual page at http://dev.mysql.com/doc/mysql/en/crashing.html contains
information that should help you find out what is causing the crash.
Writing a core file...
Working directory at /www/server/data
Resource Limits:
Limit Soft Limit Hard Limit Units
Max cpu time unlimited unlimited seconds
Max file size unlimited unlimited bytes
Max data size unlimited unlimited bytes
Max stack size unlimited unlimited bytes
Max core file size 0 unlimited bytes
Max resident set unlimited unlimited bytes
Max processes 63457 63457 processes
Max open files 65535 65535 files
Max locked memory 65536 65536 bytes
Max address space unlimited unlimited bytes
Max file locks unlimited unlimited locks
Max pending signals 63457 63457 signals
Max msgqueue size 819200 819200 bytes
Max nice priority 0 0
Max realtime priority 0 0
Max realtime timeout unlimited unlimited us
Core pattern: core
