aaPanel_Kern Hello, I suggest you check whether you have pasted the SSL certificate correctly? aaP_zondar
aaP_zondar aaPanel_Kern Hi. Yes, I inserted it correctly. Then I inserted the SSL certificate by editing the *.pem files from the post above and the certificate was applied by the panel.
aaP_zondar aaPanel_Kern I use Google Chrome. After your question, I'm beginning to suspect the web browser is the culprit in the problem. Yesterday I configured my home router and the settings were stubbornly not applied.
aaPanel_Kern Hello, is it normal to close the browser completely and then reopen it or use incognito mode? aaP_zondar
aaP_zondar aaPanel_Kern Hi. I haven't tried to reconfigure any more, it works fine. I will use a different browser when customizing the panel.
aaP_seful_ionut I had to fully disable it, and I'm not able to add it again. 🙁 At this point I wonder why my boss still wants to use this buggy and unreliable panel. 🙁
aaPanel_Kern Hello, sorry for giving you a bad experience. What is the version of the panel you are currently using? aaP_seful_ionut
