aaPanel_Kern Hello, try to use Node project deployment, you can also use the command line to deploy manually aaP_mrpk8882
aaP_angelosecu789 aaPanel_Kern I have the same problem, my applications remain in 502 Bad Gateway - Nginx, The other applications without vite work correctly, could you indicate the method for this to work correctly?
aaP_angelosecu789 I have the same problem, my applications remain in 502 Bad Gateway - Nginx, The other applications without vite work correctly, could you indicate the method for this to work correctly? @aaPanel_Kern
aaPanel_Kern Hello, please check the error log of the website. What is the cause? Check whether the backend program is running normally? aaP_angelosecu789
