aaPanel_Kern Hello, Replace 135roundcubemail.com with your domain name Modify this file: /www/wwwroot/135roundcubemail.com/config/config.inc.php Add the following: $config['enable_installer'] = true; Then browser access: http://135roundcubemail.com/installer/?_step=2 Final setup aaP_jeffrey.kroonenberg
aaPanel_Kern Hello, it is recommended that you view the logs directory under the site directory to view errors.log What is the error log prompt for viewing the site aaP_jeffrey.kroonenberg
aaPanel_Kern Hello, it is recommended that you delete the plugin you added in the site's configuration file? aaP_jeffrey.kroonenberg
aaPanel_Kern Configure the configuration file under the site config/config.inc.php The configuration of $config['plugins'] is modified to: $config['plugins'] = array('password','userinfo','newmail_notifier','emoticons','zipdownload');
