I installed the latest version of PHP or another version but it couldn't be installed even though it was successful when I checked the app store in the install section, it wasn't installed, even the latest MySQL or below!
eror
[2025-02-19 10:33:00][DEBUG] - Creating ipset aapanel.ipv4.whitelist
[2025-02-19 10:33:00][DEBUG] - Creating ipset aapanel.ipv4.blacklist
[2025-02-19 10:38:35][DEBUG] - Traceback (most recent call last):
File "/www/server/panel/pyenv/lib/python3.12/site-packages/flask/app.py", line 1821, in full_dispatch_request
rv = self.preprocess_request()
File "/www/server/panel/pyenv/lib/python3.12/site-packages/flask/app.py", line 2313, in preprocess_request
rv = self.ensure_sync(before_func)()
File "/www/server/panel/BTPanel/init.py", line 332, in request_check
return abort(401)
File "/www/server/panel/pyenv/lib/python3.12/site-packages/flask/helpers.py", line 310, in abort
current_app.aborter(code, args, **kwargs)
File "/www/server/panel/pyenv/lib/python3.12/site-packages/werkzeug/exceptions.py", line 864, in call
raise self.mapping
(*args, **kwargs)
werkzeug.exceptions.Unauthorized: 401 Unauthorized: The server could not verify that you are authorized to access the URL requested. You either supplied the wrong credentials (e.g. a bad password), or your browser doesn't understand how to supply the credentials required.
[2025-02-19 10:39:41][DEBUG] - Traceback (most recent call last):
File "/www/server/panel/class/public/common.py", line 7595, in rsa_decrypt
decrypted_data = cipher_private.decrypt(res, None)
File "/www/server/panel/pyenv/lib/python3.12/site-packages/Crypto/Cipher/PKCS1_v1_5.py", line 174, in decrypt
raise ValueError("Ciphertext with incorrect length (not %d bytes)" % k)
ValueError: Ciphertext with incorrect length (not 128 bytes)
[2025-02-19 12:41:19][DEBUG] - Traceback (most recent call last):
File "/www/server/panel/pyenv/lib/python3.12/site-packages/flask/app.py", line 1823, in full_dispatch_request
rv = self.dispatch_request()
File "/www/server/panel/pyenv/lib/python3.12/site-packages/flask/app.py", line 1799, in dispatch_request
return self.ensure_sync(self.view_functions[rule.endpoint])(**view_args)
File "/www/server/panel/pyenv/lib/python3.12/site-packages/flask_sock/__init__.py", line 59, in websocket_route
ws = Server(request.environ, **current_app.config.get(
File "/www/server/panel/class/simple_websocket/ws.py", line 325, in __init__
super().__init__(sock, connection_type=ConnectionType.SERVER,
File "/www/server/panel/class/simple_websocket/ws.py", line 71, in __init__
self.handshake()
File "/www/server/panel/class/simple_websocket/ws.py", line 340, in handshake
self.connected = self._handle_events()
File "/www/server/panel/class/simple_websocket/ws.py", line 254, in _handle_events
self.sock.send(out_data)
File "/www/server/panel/pyenv/lib/python3.12/site-packages/gevent/_socketcommon.py", line 725, in send
return self._sock.send(data, flags)
BrokenPipeError: [Errno 32] Broken pipe
please help me
