nben Hi everyone, I’m exploring aaPanel and wondered if there’s a way to set up a Discord channel or bot as an alarm mechanism for notifications. Is there an existing integration, or would this require a custom setup? Looking forward to your guidance.
aaPanel_Kern Hello, you can configure it in Alarm in Settings, Discord is not currently supported nben
nben aaPanel_Kern Thanks for the info! Do you know if there are any plans to add Discord support soon? It’d be super helpful for real-time alerts.
aaPanel_Kern Hello, thank you for your suggestions, I'll record it Is there an official website? nben
nben aaPanel_Kern Thank you! I really appreciate that. As for the official website, you can visit: https://discord.com And here’s the Developer Portal for more technical details: Discord Developer Portal It has all the info on webhooks and integration, which could be helpful for adding this feature.
