After enabling Basic Authentication in aaPanel, my Listmonk (Docker) installation broke. Even after disabling the security feature, PostgreSQL fails to start with permission errors:
`initdb: error: could not access directory "/var/lib/postgresql/data": Permission denied
chmod: /var/lib/postgresql/data: Operation not permitted
Root Cause:
aaPanel's security feature modified permissions on the PostgreSQL volume
The container's PostgreSQL user (UID 70) lost access to its data directory
I had to reset Permissions:
sudo chown -R 70:70 /path/to/postgres-data
sudo chmod -R 750 /path/to/postgres-data
