aaP_nizamdanialhasan14 I have a 403 NGINX problem after setting the domain in the settings panel, I access the panel from the domain but it doesn't work, it times out, and when I access it again via IP it doesn't work either, it gives a 403 error
aaPanel_Kern Hello, after binding the subdomain panel. Access can only be done using subdomains, IP will prohibit access to the panel. It is recommended that you use the command to unbind the domain name and access it using IP: bt 12 aaP_nizamdanialhasan14
aaP_uwe.sarpe I don't understand the doain entry under settings security, can I use one of the domains I use in aapanel? the certificate of the website points to aapanel.com.
aaPanel_Kern Hello, you can change it to your own SSL certificate and access it using your domain aaP_uwe.sarpe
aaPanel_Kern Hello, What are the hints if there is no access? What operations were done? aaP_uwe.sarpe
aaP_uwe.sarpe when I try to login, it ask me to use the domainname, than I got stuck, cause the certificate ist still on aapanel
aaPanel_Kern Hello, Does panel SSL use the domain name's SSL certificate? Can you try to close the entire browser using it and is it normal for the browser to access it in traceless mode? Or use another browser to access it Note that it is not recommended that your panel is the same as your website domain name. You can use a secondary domain such as panel.xx.com. aaP_uwe.sarpe
aaP_uwe.sarpe I could release the domain bindng, how do I replace the aapanel cert with the cert for my domain?
aaPanel_Kern Deploy the panel SSL, resolve the domain name to the server IP, and directly use the domain name + port for access aaP_uwe.sarpe
