Unfortunately I still can't install it.
here is the log
r```
oot@xxxx:~# bash /www/server/panel/install/php-ols.sh install 83
selecting download node...
begin to install lsphp83
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following additional packages will be installed:
lsphp83-common lsphp83-opcache
Suggested packages:
php-user-cache
The following NEW packages will be installed:
lsphp83 lsphp83-common lsphp83-opcache
0 upgraded, 3 newly installed, 0 to remove and 194 not upgraded.
Need to get 10.3 MB/10.4 MB of archives.
After this operation, 55.8 MB of additional disk space will be used.
Err:1 http://rpms.litespeedtech.com/debian focal/main amd64 lsphp83-opcache amd64 8.3.13-1+focal
404 Not Found [IP: 2001:19f0:5:3dcb:5400:4ff:fe2b:ace3 80]
Err:2 http://rpms.litespeedtech.com/debian focal/main amd64 lsphp83 amd64 8.3.13-1+focal
E: Failed to fetch http://rpms.litespeedtech.com/debian/pool/main/focal/lsphp83-opcache_8.3.13-1+focal_amd64.deb 404 Not Found [IP: 2001:19f0:5:3dcb:5400:4ff:fe2b:ace3 80]
E: Failed to fetch http://rpms.litespeedtech.com/debian/pool/main/focal/lsphp83_8.3.13-1+focal_amd64.deb 404 Not Found [IP: 2001:19f0:5:3dcb:5400:4ff:fe2b:ace3 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
begin to install lsphp83-mysql
Suggested packages:
php-user-cache
lsphp83 lsphp83-common lsphp83-mysql lsphp83-opcache
0 upgraded, 4 newly installed, 0 to remove and 194 not upgraded.
Need to get 10.4 MB/10.4 MB of archives.
After this operation, 56.0 MB of additional disk space will be used.
Err:3 http://rpms.litespeedtech.com/debian focal/main amd64 lsphp83-mysql amd64 8.3.13-1+focal
E: Failed to fetch http://rpms.litespeedtech.com/debian/pool/main/focal/lsphp83-mysql_8.3.13-1+focal_amd64.deb 404 Not Found [IP: 2001:19f0:5:3dcb:5400:4ff:fe2b:ace3 80]
begin to install lsphp83-imap
Suggested packages:
php-user-cache
lsphp83 lsphp83-common lsphp83-imap lsphp83-opcache
After this operation, 55.9 MB of additional disk space will be used.
Err:3 http://rpms.litespeedtech.com/debian focal/main amd64 lsphp83-imap amd64 8.3.13-1+focal
E: Failed to fetch http://rpms.litespeedtech.com/debian/pool/main/focal/lsphp83-imap_8.3.13-1+focal_amd64.deb 404 Not Found [IP: 2001:19f0:5:3dcb:5400:4ff:fe2b:ace3 80]
begin to install lsphp83-curl
Suggested packages:
php-user-cache
lsphp83 lsphp83-common lsphp83-curl lsphp83-opcache
Err:3 http://rpms.litespeedtech.com/debian focal/main amd64 lsphp83-curl amd64 8.3.13-1+focal
E: Failed to fetch http://rpms.litespeedtech.com/debian/pool/main/focal/lsphp83-curl_8.3.13-1+focal_amd64.deb 404 Not Found [IP: 2001:19f0:5:3dcb:5400:4ff:fe2b:ace3 80]
begin to install lsphp83-sqlite3
Suggested packages:
php-user-cache
lsphp83 lsphp83-common lsphp83-opcache lsphp83-sqlite3
Err:3 http://rpms.litespeedtech.com/debian focal/main amd64 lsphp83-sqlite3 amd64 8.3.13-1+focal
E: Failed to fetch http://rpms.litespeedtech.com/debian/pool/main/focal/lsphp83-sqlite3_8.3.13-1+focal_amd64.deb 404 Not Found [IP: 2001:19f0:5:3dcb:5400:4ff:fe2b:ace3 80]
begin to install lsphp83-zip
E: Unable to locate package lsphp83-zip
Package lsphp83-gd is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'lsphp83-gd' has no installation candidate
E: Unable to locate package lsphp83-mcrypt
Suggested packages:
php-user-cache
Suggested packages:
php-user-cache
Suggested packages:
php-user-cache
Suggested packages:
php-user-cache
Suggested packages:
php-user-cache
Suggested packages:
php-user-cache
Suggested packages:
php-user-cache
Suggested packages:
php-user-cache
Suggested packages:
php-user-cache
Suggested packages:
php-user-cache
/usr/local/lsws/lsphp83/etc/php/8.3/litespeed/php.ini: No such file or directory
grep: /usr/local/lsws/lsphp83/etc/php/8.3/litespeed/php.ini: No such file or directory
[OK] Send SIGUSR1 to 4539
