Nginx fails to restart after the server restart due to an error
hello
After my server crashed and restarted, nginx failed to start. When I clicked on "restart", it prompted an error.
”Nginx rule configuration error:
nginx: [emerg] module "/var/adm/510c7d52-f6d5-4cf6-bb38-1bb847f3afca/nginx/module.so" version 1027000 instead of 1024000 in command line
nginx: configuration file /www/server/nginx/conf/nginx.conf test failed“
After uninstalling Nginx, reinstalling nginx 1.27 will prompt
nginx: [emerg] module "/var/adm/510c7d52-f6d5-4cf6-bb38-1bb847f3afca/nginx/module.so" version 1027000 instead of 1027005 in command line
Installing other versions of nginx may also result in similar errors. Could you please tell me what might be causing this? How can I fix it? Thank you!
Current version:
aaPanel Stable 7.0.22
