esyede After every updates you are not introducing new features, but making it worse. Did you even test your updates before shipping it? Gosh, i'm fed up with this fucking panel
aaPanel_Kern Hello, thank you for your feedback, we will deal with it. The loading speed is slow, so it is recommended that you check whether the server load is normal? esyede
aaPanel_Kern Hello, thanks for your feedback, we have dealt with this issue. Please click "Fix" on the homepage to repair Or use this command to fix: rm -f /tmp/update_to7.pl && curl -k https://node.aapanel.com/install/update_7.x_en.sh | bash esyede
aaPanel_Kern Hello, is it normal now? Also check if we can connect to our node curl -v https://www.aapanel.com ping www.aapanel.com -c 5 ping google.com -c 5 curl -v http://www.aapanel.com esyede
esyede aaPanel_Kern Yes, it's normal now. Seems like you put those aapanel.com server on mars or something
