Hello, check if the configuration of roundcube is correct? Replace 135roundcubemail.com with your domain name
Modify this file:
/www/wwwroot/135roundcubemail.com/config/config.inc.php
Add the following:
$config['enable_installer'] = true;
Then browser access: http://135roundcubemail.com/installer/?_step=1
Final test setup
aaP_yusuf5
