tommychanckw1230244 aapanel Data validation failed and the CA was unable to get the correct captcha from the authenticated connection. How to fix it? Thank!
aaP_micjorxander how can i fix 521 error "Verification failed, domain name resolution error or verification URL cannot be accessed!"
aaPanel_Kern Hello, is the problem solved? Did you use file verification? Is your manual access normal? aaP_micjorxander
