aaP_pichoflow I have my domain with SSL, but SSL isn't showing up in my control panel. For example: panel.web.com When I enable SSL, it doesn't load. I use Cloudflare with cloud storage enabled, but it loads fine if I disable it. Why is this happening?
aaPanel_Kern Hello, Is there any error message? Is the address set by the website program using http? aaP_pichoflow
aaP_pichoflow aaPanel_Kern It was the cache, it's fixed now. I have another question: I send emails but they don't arrive in my inbox. Why is that? Everything is configured correctly in webmail.
aaPanel_Kern Hello, Please check the logs of the mail server in the App Store, send a test email and then check the logs aaP_pichoflow
