Hello,
Due to a problem we experienced:
We uninstalled some of the applications we installed in AAPANELpro. These are:
- Website Tamper-proof
-Apache WAF
- PHP code security
- System hardening
-Memcached
- Fail2ban Manager
- Log cleanup 1.3
We first installed and then uninstalled many applications such as.
Now I can't enable hotlink protection for the site. We repaired the panel. We logged out as a user and logged in again, but it didn't work.
The error we get is below :
File "/www/server/panel/class_v2/panel_site_v2.py", line 7276, in GetSecurity
data['domains'] = ','.join(list(set(re.search(r"valid_referers\s+none\s+blocked\s+(.+);\n", tmp).groups()[0].split())))
File "/www/server/panel/pyenv/lib/python3.12/re/init.py", line 177, in search
return _compile(pattern, flags).search(string)
TypeError: expected string or bytes-like object, got 're.Match'
File "/www/server/panel/BTPanel/init.py", line 2729, in publicObject
File "/www/server/panel/BTPanel/init.py", line 2676, in run
File "/www/server/panel/class_v2/panel_site_v2.py", line 7278, in GetSecurity
data['domains'] = ','.join(list(set(re.search(r"valid_referers\s+(.+);\n", tmp).groups()[0].split())))
We need urgent help. Is it better for us to reinstall the security applications or to format the server and install it from scratch? We use AAPANEL Pro.
